EM TuningAH Fabrications
Results 1 to 12 of 12
Like Tree1Likes
  • 1 Post By murran
Thread: 2.0T running a little sluggish and intermittent miss at idle
    Aug 2006
    44
    My 2.0T Quattro (manual) is running a little sluggish and suffers an intermittent miss at idle.
    Diverter valve has already been swapped out for latest D version. Have also changed the clutch switch which made a slight difference, however there is still a miss when the car sits at idle.
    The performance is also lacking compared to what it used to be. However, intermittently there is something that triggers in the car or a module that kicks back into life and transforms the drivability. This generally occurs when the car is sitting idle for a bit (in traffic or at lights) or switching engine off and on after its been driven for a bit. (This is what makes me think its a module that kicks back into life).
    It appears to be a airflow problem of some sort but we just cannot pin point it.
    The car has recently had a service during which the air filter was also replaced (clutch switch changed at same time).
    Any recommendations on where to go next will be much appreciated. Or a recommendation to decent specialist in east London will be good.
    Thanks in advance.
    A4 2.0T FSI Avant S Line Quattro - Phantom Black
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,534
    1st off i would get it scanned for fault codes
    then take it from there
    May 2011
    Glasgow Area-ish
    62
    Have you had the coil pack recall done?
    Aug 2010
    1,540
    Revving on Idle
    Problems :( Irratic idle issues
    can you remove the oil cap easily while the cars ticking over? what does the idle speed do?
    Aug 2006
    44
    Firstly, thank you for all for the replies so far...been busy reading about all that's been suggested so far and now I am thinking it could be many things....please nooooo..! I absolutely love the car (the most fun of all that I have owned) but dont want to start spending silly money putting it right!
    The coil pack recall was carried out May 2011.
    I have had the fault codes read and the car has 1 logged;
    01602 - Electric drive motor (V141) sporadic 002 - lower limit exceeded.
    Have googled this and I cannot find a definitive resolution for those (there are a few) that have experienced this. Found something on the GTI forum pointing towards intake manifold tumble flap.
    Any other suggestions on where I can go next with regards to the above or is it a code thats as a result of something else that maybe wrong.
    Ive also read that VW/Audi US have a recall on the Intake flap module and PCV for all TFSI engines. Has anyone heard of this here in the UK?
    Thanks in advance again.
    Aug 2006
    44
    Murran - I did attempt to take the oil cap off when engine was running and yes its was a bit of a struggle to remove it.
    Also the revs were very unsettled once I did manage to get it off.
    Does this indicate an issue with PCV?
    Aug 2010
    1,540
    yes, yes it does. it should be no more difficult to remove the cap whether its ticking over or when the engine is off.
    what causes the difficulty in removing the cap is the vacuum created in the inlet manifold being transfered to the crankcase via the faulty pcv valve. this vacuum holds the cap down.
    if you manage to remove the cap on one thats faulty the engine will struggle to tick over at all.
    but on one thats fine, it just upsets the idle slightly.
    prel2000 likes this.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    206
    Do you know if the PCV from an A3 2.0T BWA is interchangeble with one from an A4 2.0T BWE?
    Reason I'm asking is audi have told me there is no problem with my PCV valve (which they supposedly changed 2 weeks ago) and I want to prove them wrong by putting my A3's valve onto my A4 to see if it sorts the issue.
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    Aug 2006
    44
    Has anyone had this or recognise this code and know where to go with it?
    The intermittent miss on the car can also be replicated when using the electrics i.e. when toggling window switch, cental locking and power steering, so I am wondering if I have a electrical problem?
    Aug 2006
    44
    Just to provide an update on this problem for those looking for a solution...as my problem is RESOLVED..!! wohoooo..!
    Basically changed the Crankcase breather valve (AKA - PCV).
    No more miss and the performance is back...all the 249 Brake Horse (after AMD remap) are now back in full flow...boy did I enjoy the commute today!
    I dont have the part number to hand but will list that here to make life easier for those wanting to order one. Its the same part for most of the engine numbers.
    Special thanks to Murran for pointing me in the right direction..TOP MAN..!
    Aug 2010
    1,540
    as a comparison did you try the "removing the oil cap while ticking over test" again once youve changed the valve?
    Mar 2012
    North Wales
    121
    Hi all.. I too have had the same probs with the pcv. I ordered the part from my local Audi dealer. It cost me 36 pounds all in, this did not include the seals.. anyway the part number is 06F129101N.. I was told this is the most upto date version there is. This is for a BUL designated petrol 2.0 ltr turbo quattro engine . Not sure if it fits other types of engine? Hope this helps anyone..
  1. amber light with a little car and key in it...
    By ALPINE in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th April 2010, 22:39
  2. My 2002 TDI is idling a little heavy and loud
    By sleven5 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th May 2009, 23:23
  3. Done a little Polishing and Painting
    By Roach in forum Photography & The Digital Darkroom
    Last Post: 9th May 2008, 11:59
  4. Little boy and his mum
    By lil_coz in forum Jokes, Games & Humour
    Last Post: 8th May 2008, 09:31
  5. Fancy a little show and shine meet 5 or 6th May?
    By TonyT in forum Smaller (Local) Events
    Last Post: 16th July 2007, 19:07
