Chris NottEM Tuning
Results 1 to 30 of 30
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    Best front discs for replacing drilled discs?
    Need to replace the front pads and discs,are oem best option? I have the vented and drilled discs and large brakes (same size as old s4). The set up seemed good for what I use it for, but wondered if a better option for the same money our less....
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Quote Originally Posted by razza1 View Post
    I upgraded my 3.0 discs and pads all round for some drilled discs, Mintex pads (dont touch redstuff) and i changed all the rubber lines for custom made braided hoses.
    Made a hell of a difference and much cheaper than adding bigger discs or messing around.
    I found the S4 calipers and standard discs on mine are ****e!, hence just a few changes they seem much better.
    I dont think you have a better option razza, maybe try changing your pads or upgrading your lines, but unless you spend £500+ your not going to get anything ground breaking
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    Do mintex have the sensors built in or not, if not how do you avoid a brake warning light?
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    721
    Yes they do, mine do anyway. Ive got these
    MTEC Brakes, Performance Brake Discs, Sport Brake Discs
    They do a complete package
    P.s also went for braided hoses
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    How do you find the mtec ones? What did you have before?
    rizzini7's Avatar
    Jun 2011
    721
    Was fitted with standard audi brakes. They seem fine a damn sight sharper. Although the old one were knarckered
    Missed gear
    Jan 2006
    Kent
    386
    Seem a good price for the Mtec ones - £210 complete set - link
    My discs have a quite a lip on them so may give these a go.
    B7 A4 Avant S-line Special Edition v2 2.0 TFSi - AmD stage 1 - 263Bhp 396Nm
    rizzini7's Avatar
    Jun 2011
    721
    I went for the painted ones so the rim doesnt rust up.
    solaris's Avatar
    Slough, Berkshire
    404
    I've been using MTEC drilled discs and HAWK HPS pads for about 8k miles, initial byte from cold is good and when they warm up its even better, I've not felt any fade from the brakes after those spirited drives either. The pads dust less and come with Hawk supplied lubrication. Highly recommended.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    What cost at a garage to fit? How long a job is it for a garage fit the fronts discs and pads?
    Oct 2010
    32
    I recently fitted Pagid High Carbon discs and matching pads bought from Eurocar parts and I am very impressed with the difference they made over the standard discs and pads.
    Good price too.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    How much were they then for those?
    Found them, what's the high carbon finish then, and what's the benefit, or is it just a finish that wears of quickly?
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    940
    Just fitted pagid discs as part of bbk ,mine came painted which wears off braking surface but should slow down corrosion in the long run and only £46 each even for the big discs.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO ST2 MAP ,MILLTEK CATBACK EXHAUST,PANEL FILTER,034 INTAKE PIPE.
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    Audi want over £500 to do the fronts, reckon its excluded from the £259 deal as the parts alone are more than that...anyone had the vented, drilled discs and large pads done under this Audi deal? Sent a query to head office on it as its still only a 2ltr therefore should be in the deal....
    Jan 2012
    1,837
    Was about to say you should be covered under the fixed price servicing as its up to and including 2ltr engines and no mention of brake sizes etc.
    Tbh you would be better ringing 0800 699888 and speak to customer service direct.
    Let us know how you get on
    gkf9's Avatar
    Jul 2007
    Lancashire
    256
    Got front discs and pads fitted at an Indy last week... Hour and a half labour £63 inc vat.
    2003 - Akoya silver A4 1.9 tdi (100) Sport
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    spoke to audi, they said it's the £259 regardless as there's no exceptions and Reading Audi aren't correct. He's going to phone Reading and get back to me, so will wait and see...he's confirmed to me though already, so I'll be pushing for that as the parts were over £300 alone (the total cost was >£500 and only 1hrs labour...)
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    spoke to audi again, he said after speaking to Reading Audi there's no way they can do it for that price due to the size of the discs and that they're drilled and that the pads are also massive....not all special editions had them and therefore they will be excluded form this deal even though it doesn't mention it on the website.
    Used this clause on the site: "Offer may be varied or withdrawn at any time." looks like I'll not be going OEM then, just need to get a correct price for non OEM replacements...
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    hmmm, looking at the mtec ones, not sure whether to go silver or black edition as an extra...
    MTEC Brakes Black Edition Performance Brake Discs
    thoughts?
    rizzini7's Avatar
    Jun 2011
    721
    I went black, i soon wears off just leaving a black rim and grooves
    solaris's Avatar
    Slough, Berkshire
    404
    thoughts?
    Exactly how long will the black ones be black?...save your money mate
    rizzini7's Avatar
    Jun 2011
    721
    its more the paint stops the rim rusting. Only £20 more for the paint
    andymartin045's Avatar
    Sep 2010
    RAF Leeming, North Yorkshire
    47
    i spoke to teeside audi and they said they were willing to stick to the fixed price plan for the brakes for my car (220bhp with drilled fronts)
    harrogate audi blew my off saying that they would (obviously) loose money. they stated that the front disks and pads alone would cost £560!!! while teeside agreed they can do the same for £249!!! go figure
    2005 2.0T DTM quattro 281bhp,
    Carbon Fibre, MFSW, BOSE, Bluetooth, Parking Aids, Nav Plus, Recaro Leather & Alcantara, S4 Mirrors, RS4 pedals, H&R springs, RS4 ARB, Spacers, Debadged, Auto Lights/Mirror/Wipers, Silent Forge DV & Vredstein Ultrac Sessanta Tyres. Awful Mileage and some TTS Roadsport stickers!
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    wow, that's lucky I would get that in writing or get in there quick, I've seen the prices for the parts....and Harrogate are right. I've got a very good relationship with Reading Audi and there's no way they would do it for the fixed price, even the main Audi customer service guy who said originally they should have to stick to it, came back and said there's no way due to the cost of them being prohibitive
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,184
    Typical! Just got the brake pad worn light come on today. Don't want anything fancy but wondered if anyone had experience of the drilled discs and used these:
    Audi A4 Avant 2.0 Tdi 01/05-02/08 front and rear brake discs with mintex pads [17585] - 167.70 : MTEC Brakes, Performance Brake Discs, Sport Brake Discs
    Will these fit my 2.0 TDI 140?
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    I have Mtec's with Black Diamond preditor pads.....awesome stopping power :-)
  28. #27
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Quote Originally Posted by andymartin045 View Post
    Lol, where do audi get their silly prices from?
  29. #28
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    Went to an indi earlier today and discs still have life in them, so just pads needed :-) they use pagod pads or something...
  30. #29
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,238
    The discs would have been £200+ in parts alone, same as oem but without the stamp.. .
  31. #30
    carl-1968's Avatar
    May 2012
    Nottingham
    455
    Mtec disks(all 4) black edition £170, pads £76, I thought it was a cracking deal so went ahead and brought them
  1. Best drilled discs for 3.2 A3
    By TAC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2011, 18:16
  2. cross drilled disc brakes for A6 C6 3L TDI
    By carty80 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 28th June 2010, 14:26
  3. Drilled Discs for 08 S3
    By d8vil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2009, 19:16
  4. Replacing A3 discs and pads, things to look out for?
    By Voodoo in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th September 2007, 23:06
  5. Replacment Discs for Brembo GT
    By HmanS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th March 2007, 15:16
