Chris NottEM Tuning
    AjM
    AjM's Avatar
    Living in Blissful Ignorance
    Jan 2007
    Torbay, S.Devon
    295
    Question Elec Wing Mirror with mind of its own?
    Can anyone help.
    My passenger wing mirror is alive. When i unlock the car, or sometimes when i turn the ignition it adjusts itself to a random position as far as it can, for instance, up, and then continues to try and go higher for about a min. The direction it goes changes all the time and it does not do it everytime, prob about 90% though. It is getting on my wick now, no faults with vcds, any ideas?
    27,129
    Urm check few things, like door switch, wiring in the pillar maybe damaged in the grommet, maybe somethings shorting, remove door card & check for any water ingress in electrics, variety of things to check 1st before getting serious tbh.
    AjM
    AjM's Avatar
    Jan 2007
    Torbay, S.Devon
    295
    Ok, will do, thanks
  1. Fuel gauge indicator with a mind of its own
    By tquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2012, 08:24
  2. 1999 A6 tdi central locking with a mind of its own.....HELP!!
    By alibob in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th December 2009, 20:21
  3. Concert with a mind of its own!!!
    By alibob in forum In-Car Entertainment
    Last Post: 27th February 2007, 14:00
  4. Petrol gauge has a mind of its own
    By PaulBelsham in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2004, 10:37
  5. My clock has a mind of its own
    By Kevint in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2003, 12:52
