Volks AutosSky Insurance
Results 1 to 9 of 9
    Mar 2011
    North Wales
    210
    Question 2.0 tdi accelerate problem
    Hi,
    The car runs fine when cruising along but when I accelerate there is a slight pause and stutter before it actualy accelerates. it also does it on cruise control when you lift the stalk. It's had a new egr about 5k ago as well as 4 injectors and loom on recall about a year ago.
    I've started by putting in a new fuel filter but it's made no difference.
    Any ideas where to look for a diy attempt at resolving this ?
    2.0 TDI 170 2007
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Sounds like there maybe a hole in a hose possibly the one leading from the EGR.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    May 2012
    Derby
    Let me know how you get on pal, iv got the exact same problem, very annoying..
    Oct 2009
    166
    Quote Originally Posted by mm707 View Post
    Hi,
    2.0 TDI 170 2007
    Does the engine stutter when the car is stationary out of gear?
    Audi A4 Avant TDI 170 S-Line
    1992 Saab 900 T16S Convertible
    Mar 2011
    North Wales
    210
    no - slightly uneven tickover now and then but other times its fine. Going to put some millers injector cleaner through this weekend and see if it makes any difference.
    Oct 2009
    166
    Assuming its manual could it not be transmission ie clutch & dmf rather than engine as it only does while on the move?
    Im no expert but thinking it through logically having read all the past threads on forums like this?
    Jul 2011
    BRISTOL
    12
    Does this happen around 1600-1800rpm?
    Mar 2011
    North Wales
    210
    Quote Originally Posted by Wombatwilson View Post
    I guess it probably does - I'll have a look next time I'm out but it is definately just as I'm accelerating
    Apr 2012
    12
    I have the very same problem and yes thats when it happens, so annoying
  1. The Vibration on Acceleration Problem, DSG 2.0 TDI, Advice Needed.
    By waz88 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th June 2014, 18:26
  2. A3 1.9 TDI - Boost Problems
    By turbodan in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2006, 10:30
  3. 2000/2001 A3 TDI (ENGINE PROBLEM)!!!
    By mr964porsche in forum Diesel forum
    Last Post: 26th June 2006, 23:32
  4. A3 TDI turbo problems
    By GarryA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th April 2006, 13:25
  5. A3 2.0 TDI Starting problems
    By imported_simey in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th February 2005, 20:18
