Results 1 to 12 of 12
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    How high does the S-Line body sit?
    Noticed yesterday that I can barely squeeze two fingers between the top of the rear tyres and the bodywork. I've had comments before about how low it is thinking I've purposely lowered it, which I haven't. I assume my stock springs are tired so, how high would stock Audi springs make it? Is it worth putting a different set on the back, I don't particularly want to change the front as well as there is nowt wrong with them.
    Comments please guys.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,988
    they should sit at least 3 fingers
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Must be pretty tired then. Would it be best to replace with OEM or something like Eibachs?
    Nathan
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    The eibachs seem pretty good, ride is still bumpy but sure it felt less harsh than oem
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Mar 2009
    589
    Quote Originally Posted by razza1:1590066
    I have h&rs and i also think ride is better than stock or at least no worse !
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Quote Originally Posted by Marrow View Post
    What's the height difference between stock and the h&rs?
    Nathan
    Mar 2009
    589
    Not sure think.its quotrd as 45 mm so thats 25 for an s line ? Mine came down a lot more that that though !!!
    Jun 2011
    NW London
    141
    nice was just gonna ask you to post a pic, that looks a lot lower than this chaps
    Anyone got an A4 (B7) lowered on -35mm H&R springs
    u got a full tank in that photo?
    cheers
    matt
    Mar 2009
    589
    Actually i think they are 35 mm drop now.i have seen that ! Na avants just sit lower at the back i do have b5 caps on the front which adds another 10mm to the front drop though which a cheap effective mod.
    northernlight's Avatar
    Sep 2011
    56
    Had mine replaced recently with the Eibach Pro Kit - 35mm drop. Ride is similar if not slightly better than original and still keeps reasonable height but low enough to improve the looks. Pic attached isn't great but gives an idea....
    08 2.0 TFSI Quattro SE V2, Milltek RS4 system, RS4 ARB, AMD Stage 1 remap, Xenons, Valcona leather, RNSE, Eibach Pro Springs, Bose.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Where'd you get the Eibachs from?
    Nathan
    Sep 2011
    56
    Quote Originally Posted by Wrath View Post
    AMD Essex. They were doing a good deal to supply and fit. Was about £360 i think. Given the labour time to replace the springs this seemed like decent value.
  1. Why does the s line kit have no side skirts?
    By dappa786 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th July 2008, 00:27
  2. How long does the Boat take to set sail?
    By copperband in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd May 2007, 15:25
  3. How high should the coolant level be?
    By ImS3ola in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd November 2004, 17:13
  4. How well does the 1.8 engine cope with big mileage
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2003, 22:26
  5. How much does the heat affect BHP??
    By Drystone in forum Other Brands & Models
    Last Post: 25th April 2003, 19:41
