Sky InsuranceEM Tuning
Page 2 of 3 FirstFirst 123 LastLast
Results 41 to 80 of 103
Like Tree9Likes
Thread: Another 2.0TDI EGR Valve Cleaning Thread - with before and after pics.
  1. #41
    i_786_i's Avatar
    Aug 2012
    57
    Good Luck!
    Check all components are moving freely, and clean the pipes also. What I did was thoroughly clean around the egr and throttle first and then block off with a cloth until ready to fit the parts back on just so no dirt accidentally drops in. It should be pretty clean already and you may see some oil which is normal.
  3. #42
    Oct 2011
    Cumbria
    89
    Just a question but should the small valve on the EGR be easy to open? I only ask as I couldn't open mine but presumed the motor under the black plastic cover was stopping it from moving
    A4 Avant tdi S-line
  4. #43
    i_786_i's Avatar
    Aug 2012
    57
    Quote Originally Posted by Daemon View Post
    Both the valves are electronically controlled. Although the throttle valve is in an open position already you can still open the egr valve. I used a bit of force and was able to open this (use flat screwdriver wrapped tip with cloth to keep open). Dirt accumilates under here and can cause valve to stay open.
  5. #44
    Nov 2011
    171
    I went to Audi on Thursday and collected my new gaskets and seals. I was planning on fitting them tomorrow but... rather strangely today the car hasn't juddered once. I have been out and about in it for most of the day and it hasn't juddered once and felt perfect on every shut down yet i haven't touched it at all ?
    Strange ! I am now in two minds whether to fit the new gaskets and seals or whether to just leave the thing alone. Any ideas why it has suddenly started behaving ?
  6. #45
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by Oddie View Post
    Sounds a bit like when I take my dog to the vet........ It knows!
  7. #46
    Nov 2011
    171
    Quote Originally Posted by Richardesty View Post
    Haha, it sounds exactly like that ! I was all set and ready to get my hands black tomorrow morning but now I am not sure whether to bother
  8. #47
    Mar 2011
    North Wales
    206
    Quit while you're ahead , you've always got the parts ready if it misbehaves again
  9. #48
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    Just thought I'd update on my progress on this topic...
    I ran the BG44 through a full tank earlier in the month with a mix of economy spec commuting, mixed throttle country lane driving and motorway with a few full load runs up to high speed. Conclusions are:
    - Still misfires on warm startup
    - Started to smoke slightly on full throttle accel
    - Seems to pull more keenly (makes the car feel lighter or as if the handbrake was on one click before)
    The last point seemed a clear positive as the car is definitely pulling better now but with this better revving it's highlighted a light misfire (hesitation) throughout the revs once it's on boost. I assumed this was something like EGR or injectors or maybe the MAF.
    I went to Audi and bought a gasket set for the EGR assy (thanks for the part numbers chaps!) and spent a hour or so cleaning out the EGR assembly (which was full of crud as per the previous guys).
    - Stopped smoking completely
    - Still hesitates under full load
    - Pulls the best since owning it
    - Engine stops really cleanly on key-off (this is Reeeally noticeable)
    I also made up an EGR blank and tried this to see if there was any noticeable difference between a clean EGR and no EGR, however the car went MIL on and into limp straight away, so this came straight out. (I now need the light resetting!)
    I guess the smooth cut off is down to the anti judder valve being clean and woking properly, the hesitation is still there so I'm going to wait for its service next month and then look at having the injectors cleaned and possible reblanking the EGR but with the software modded to accept it.
    I'm also going to run another can of BG through after the service and then see where we are.
    To be continued....
  10. #49
    Mar 2011
    North Wales
    206
    Mine was the same, changed the vacuum unit on the inlet manifold and it is sooo much better now, been about 2 months and not a blip.
    You need to take the egr off again and then remove the inlet manifold, dead easy as long as you know beforehand ( which I didn't ) that there is a bolt inside the air intake which is covered in crud so you cant see it
    Change the vac unit, it's obvious how to do it once the manifold is off and also clean all the flaps in the manifold with carb cleaner - they will be filthy too.
    vac unit is about £10 and the manifold gasget about £3 from TPS
    I opened up the old vac unit afterwards and the diaphragm inside had a hole in it.
  11. #50
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    Thanks for the reply, however I'm not sure what part you're referring to though? What does the vacuum Do you have any pics?
    Just to check it is the 2.0 not the 1.9 you're talking about right?
  12. #51
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    This is the 2.0 inlet manifold, I can't/couldn't see any vacuum system attached, also the EGR and anti shudder are fully electric?
  13. #52
    Mar 2011
    North Wales
    206
    Quote Originally Posted by tr3m5 View Post
    2.0 tdi
    At front of engine near top
    Main dealer may not find this part however the part number
    is S03G129061C
    better still go to TPS they are much nicer in my opinion.
    I think it controls the flaps inside the manifold which adjust the air
  14. #53
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    Ok I've found the valve...
    Can't seem to find anything that says what it does but for not a lot of money I think I'll change it, would be great if it solved the remaining niggles.
    Cheers mate, I'll let you know how it goes!
  15. #54
    Mar 2011
    North Wales
    206
    Please do and have a can or two of carb cleaner at the ready for the flaps in the manifold
  16. #55
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    Just been to Audi (it's around the corner from work) and paid £14 for an inlet manifold gasket and the valve. Looks like that's my sunday morning booked then....
  17. #56
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Let us know how you get on as I hate starting work on my car because everyone said it was simple and then find out it is anything but (usually screws not shifting etc).
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
  18. #57
    i_786_i's Avatar
    Aug 2012
    57
    I always spray a bit of wd-40 before starting the work, and making sure I have all the right tools... took me 20mins to strip pretty straight forward I found.
  19. #58
    Mar 2011
    North Wales
    206
    Don't forget about the bolt inside the air intake, it will probably be covered in soot. It caught me out, I spent about 15 minutes tapping the manifold all round with a piece of wood thinking it was stuck on
  20. #59
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    What's the part number of the manifold gasket?
    Nathan
  21. #60
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I don't appear to have a vac unit. Was this added to later engines (I have a BLB).
    Nathan
  22. #61
    Newbos's Avatar
    Sep 2012
    115
    Took my egr off today and it's wasnt as dirty as I thought it would be, but still had some build up, so cleaned it all. Didn't take long and refitted easily. It is fiddly but not hard. Didn't take the inlet off, but I'm hoping just doing this will help.
  23. #62
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Nathan
  24. #63
    Mar 2011
    North Wales
    206
    Quote Originally Posted by Wrath View Post
    Looks like it but if you go to TPS it's only £2.90 + vat , I don't think it would be a great deal more from main dealer
    I think the part number is 03G129717D but it's worth double checking as I have 3 items on my invoice and it only says part number and 'gasget' for each one
  25. #64
    Jun 2012
    7
    Hi there, I've had the same fault and my emmisions control light is on. audi told me a new evr valve is needed. however, this thread has been a great help. My egr was quite dirty but nothing like as bad as the first pics. So now I've cleaned it, changed the gaskets and put it back together. The dam light is still on even after unplugging the battery for a while in hope to reset the EGU.
    The two cogs inside the black plastic box seem quite worn could this be causing the light to stay on? Not sure what else I can do without replacing the whole valve. Any help is very gratefully received. Cheers
  26. #65
    Aug 2012
    9
    neilenty, same thing happened to me... cleaned the egr which wasn't really that dirty ... but the damn light still wouldn't go off... so i took the vag com and erased the error (motor for intake manifold flap v157 no signal error). unfortunately for me after just leaving the service stopping the engine and starting it for a few times, the light went on again.
    today i bought the damn piece, a Siemens VDO egr - and i'm going to mount it this Saturday.
    i advise you check out this link: 19558/P3102/012546 - Ross-Tech Wiki, and try to check the fuses and the wires connecting to your egr, Ross Tech recommends to check them out before actually purchasing a new EGR valve.
    forgot to ask: do you experience hard shudder when turning OFF the engine? That's what i'm having plus the fuel consumption seems higher these days!
    i will keep you posted with my progress
    thanks,
    Stef
  27. #66
    Jun 2012
    7
    Hi steff
    no shudder. My wiring in to egr is fine (as far as I can tell). Not checked any fuses though. will do that. so still a little confused... Thanks for the reply
  28. #67
    Aug 2012
    9
    you should probably try deleting the error with a vag com if you have any... if i remember right the first times it happened to me the car had no other symptoms except for the yellow light... after a few days/weeks it started to shudder when i turned the engine off... check your fuses first, do a full diagnose and see what error you get.
    keep in touch .
  29. #68
    Jun 2012
    7
    Audi did a full diagnostic the other day when it has it service, but they only said that the ecr valve needed replacing.
    I don't have a vag com myself and don't know anyone with one (except a garage, but I've just moved into an area and don't have any garage that i know/trust (Bolton).
    Ive just checked all the fuses and they are all ok.
    I'm wondering if the light would reset on its own if the dirt was causing the fault? because if it doesn't then it may be ok but needs resetting once reset. if it does then I may just need a new valve? Having said that, when I took the valve off it was in good condition, albeit dirty, however the white cog in under the black flap was worn in one part and so was the large black cog where the two meet. As such I wonder if this could be causing the light to stay on?
    i just don't know. Any help is very kindly received.
  30. #69
    Aug 2012
    9
    neilenty i don't really know what to say, some pictures would really help. audi is probably right about this, but if the car has no shudder when you turn off the engine then you can probably still use your current egr valve. believe me your car will shudder like hell when the egr valve is broken - this is my case. i would firstly recommend you get in touch with someone who can delete the error (i actually own a vag com replica, spent $30) and see if it's going to come on again...
  31. #70
    Jun 2012
    7
    OK i see.... not the best picture in the world as i didn't really think about it at the time photo (4).jpg
    Do you reckon would that work? VAG Scanner Code Reader Airbag Reset SRS ABS Oil service COM CAN BUS K-Line OBD2 | eBay
  32. #71
    Aug 2012
    9
    it's okay... if you cleaned it and placed everything back together then your egr is probably fine. by the way i noticed that you also opened the egr electronic part (that black plastic box), did you noticed any oil leaks there?
    as for the vag com, no that's not what i use: Wholesale vag 11.11.3 VAG 11.11.2 VAG 11.11 VAG11.11HEX CAN USB Interface VW Audi Diagnostic Cable, Free shipping, $15.67-20.52/Piece | DHgate -it's chinesse but trust me it works okay!
    this is what ii have.. you will also need a notebook with windows xp or 7. you can then delete/check all your errors!
  33. #72
    Aug 2012
    9
    btw, that's what i found on a quick google search, i'm not the one selling the product! try finding one in your city, so you can actually test it!
  34. #73
    Jun 2012
    7
    Cheers... there was no oil leak in the electronic part. The white cog was a little loose, looks like some of the plastic that holds it in place was worn so it had a little play in it and there were tiny bits of plastic loose in that area.
  35. #74
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    Quote Originally Posted by daveevs View Post
    There is a rubber seal between the anti shudder valve and EGR body, a gasket between the EGR valve body and inlet manifold, and another gasket between the EGR pipe and EGR valve body.
    It's been just over 2 years since I cleaned the EGR valve and now I only make small trips thought I'd check it and clean the intake manifold as well. Lumps of carbon had formed so cleaned it all and made my fingers black (wear gloves people!). Some tricky placed bolts as well. Thing is, I changed the seal on the above but the one from the dealer looked like a red rubber band but the one already in was flatter and more cylindrical. Is there a different seal between the 140 and 170?
    Nathan
  36. #75
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    Update
    I know it's been a while since I last posted, I got sidetracked with a house extension so the inlet manifold and vacuum unit never got a look in...
    Anyway, the car has been running well lately no issues on startup, still a little smokey on full load at certain speeds but only thing really bothering me has been the 'flat' feeling when accelerating from low speed which it has always had. Obviously i expect some turbo lag but it feels like more than that and after trying a mate's '05 2.0TDi i'm convinced its not right.
    Summary of where I am now:
    - No fault codes
    - Recent service, including fuel and air filters
    - Run BG244 through the system
    - Cleaned EGR valve and intercooler pipework
    After cleaning the EGR I didn't want it re-coking so after my first attempt at removing the EGR with a simple blanking plate (resulted MIL lamp and limp mode) I recently spoke to a few people about mapping it out. After a few phone calls, emails and forum searches I got in touch with Mike at Motech in Northampton and he offered to map out the EGR and apply his 'mild' remap (35bhp/50Nm) at the same time. I went ahead with this today and although I'm happy now that the EGR valve is out of action the re-map doesn't seem to have altered the performance much, and certainly not ~25% more power.
    I'm a little surprised as there are plenty of happy customers with the same car, Mike commented it didn't seem to feel quicker and was smoking more than other TDi 140 PDs and offered for me to drive it for a couple of weeks and he will give me a refund if i'm not happy.
    It's only day 1 and he advises that the ECU adaptations need to take place to get full effect, but my initial impressions are that the throttle response is definitely quicker (different throttle map) and the car seems to run more smoothly (no EGR?). I haven't blanked the EGR yet but it is mapped shut and Vagcom confirms its stuck at 100% closed at all times.
    Mapping wise Vagcom shows a higher fuel delivery pressure and an increase of around 0.2Bar boost (only at high throttle demands), we discussed the performance with the guys at VRS in Northampton and they think based on the state my EGR was in before then cleaning the inlet manifold may make all the difference.
    As per my previous posts i bought a new inlet manifold gasket and vacuum unit so i'm going to do the manifold this week and while i've got the car in bits i'll fill the turbine housing with Mr. Muscle oven cleaner and see whether and underperforming VNT may be contributing (VRS think this is normally an issue on cars with high mileage on the clock).
    So with the above in place there really isn't much more i can do other than have the injectors properly cleaned (which I don't want to do).
    I'll post pics of the inlet cleaning and update on the car's performance...fingers crossed
  37. #76
    tr3m5's Avatar
    Audi Newbie
    Aug 2012
    Northants
    34
    spent 5 hours on the car this afternoon...
    First stripped the Inlet assy down, bearing in mind i cleaned the EGR valve around 5k miles ago it was in a terrible state again today:
    Now that the valve is fixed closed I cleaned it all back to shiny bare metal again and fitted an ally blanking plate I made from 1.2mm sheet along with another gasket.
    I then got the inlet manifold off and as expected it was badly caked in black sludge, over 5mm thick in places! My chosen cleaning method was to scrape out the big chunks and then fill with oven cleaner, leave for 10 mins and then thoroughly blast the innards with a power hose... after 2 rounds the insides were silver again and the switching valves shiny and free to move fully. I also fitted a new actuator even though mine worked fine as they are such a cheap part l.
    While the inlet assy was off I also got the oven cleaner down the ports and have them a thorough clean as they were equally caked in thick carbon build up.
    I also cleaned the intercooler top hose hose and looked at taking the cooler off to clean it internally but it looks like the bumper and grille need removing to access so have it a miss.
    Then I went around the other side if the engine and removed the air box to get access to the turbo. Again the VNT felt fine but I removed the bung out of the turbine housing and filled it with oven cleaner.
    While I was doing this i noticed a load of soot around the cooler, turns out the integral pipe between turbo and EGR cooler is leaking where the flange is brazed onto the pipe. I took it off and double checked and the gasket is fine so definitely the pipe, this certainly won't help the low down torque and may be contributing to the flat spot, so now that the EGR is disabled I'm going to make a stainless blank and blank the pipe off right where the EGR leaves the manifold, having looked at the system I'd recommend doing this anyway if you have EGR mapped out as any additional volume (ie pipe between turbo and cooler) will slow down turbo spool-up and this will be even worse if the pipe leaks like mine.
    (Pic shows leaking flange)
    I didn't have time to make a blanking plate today so built everything back up with new gaskets where required and tested it.
    Unfortunately the flat spot is still there but definitely lesser and the car seems to drive much more smoothly, especially when accelerating, power is much more progressively delivered and less smoke for sure.
    If I can find some stainless sheet ill finish the job by blacking the EGR off at the cooler tomorrow and that is pretty much all I will do now other than run another tank with BG244 now it's EGR and sludge free...
  38. #77
    Jul 2013
    Durham
    Did the blanking plate fix the sluggish feel at low rpm.............
    I have been reading the thread and was interested if the blanking plate cured the slow response at low rpm......
    I had the EGR mapped out and the DPF removed but car just feels the same........I really believe that there is some mileage in the vacuum theory regarding leaks or the vnt is sticking......
  39. #78
    Jun 2013
    is this part known as the air intake manifold actuator and flap that Audi quoted me £1200 to replace?
  40. #79
    Jul 2013
    Hello All
    I'm a Mulitskilled Engineer .....I fix things
    Anyway .. My symptoms on AUDI A4 2006 73k on the clock .. on my way to ireland it lostpower.... It was an intermittent fault loosing power then regaining it again. overtaking on a hill was a hit or a miss ..very frustating ..intermittent faults are always the hardest to diagnose than a component failure .
    As per blogs I cleaned out the EGR valve which was as clogged up with carbon... so I thought FIXED.. I was wrong !!
    I nearly gave up .. I was about to take it to a garage as my colleagues had suggested.... butI thought .. to get beat .........na.....
    T does not not give up... I decided to look at the motor and gearbox within the EGR.... So one again I removed it ....I had to overcome one of the bolts holding the Motor gearboxcover being plugged up with a glue type resin... why would Audi do such a thing ... £££££££..... I used a knife and some patience to overcome... see pictures attached.. COGS were worn away.. so worn that the mechanism wouldn't work ... so I drilled a hole fitted a screw...work it out if you can its in the pictures... I'm at full power all the time.. I know the valve wont fully close but its not made any differenceto the cars performance.
    Also my symptoms were of erratic idle. the car shook a bit every know and again
    Yesthe part needs changed......in due course.. £159 on ebay
  41. #80
    Jul 2013
    Hello All
    How do I attach pictures.......
  1. I know we have a 'pics' thread - but how about some B7 BEFORE AND AFTER Photos?
    By Richardesty in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th February 2012, 20:22
  2. 2.0tdi egr valve fault and less MPG!
    By navnayyar in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st June 2010, 13:55
  3. A6 C6 3.0tdi quattro EGR valve clean
    By singhl in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 4th August 2009, 12:12
  4. another before and after
    By buckas in forum Photography & The Digital Darkroom
    Last Post: 21st June 2007, 12:37
