JMB RetrofitsSky Insurance
Results 1 to 13 of 13
    May 2012
    Audi a4 170 2.0 tdi problems
    Hi guys i am new on hear but have used the site for great information and hoping that I might be able to get some help really.
    I have a A4 2.0 tdi 170 56plate 74,000 miles
    Recently took the car to Audi for the injector recall (last week) because I found out I had not been done so thought it would be a good idea to get new ones put in FOC.
    There wasn't really any problems with the car before I took it in but now the car has started playing up, on and off power like it stuttering only on low revs motorway is fine but drop your speed down and it's like it's missing?
    Audi only replaced 3 injectors and wiring a they said one injector had a modified unit in, I don't believe this as they had never been changed before, could this be true?
    Anway the car seems to be getting worse the more u drive it and was hoping anyone could help with advice and what to do? Do I just give it Audi back? But I don't wanna get hit with a big bill. Could it be the injector that hasn't been changed and should they have changed it? Also had a search on hear people having problems with egr valve or fuel filter! But the car wasn't playing up before it went into Audi.
    Any help would be much appreciated as I am un sure what to do
    many thanks
    paul
    Also working nites that why I am posting threads at this time cheers
    D8UGF's Avatar
    Oct 2006
    Lanark
    107
    HI mate,
    Obviously with you looking on this forum you can see there are multiple issues with these cars that can lead to the sort of symptoms you are experiencing. I think you would be most within your rights to say that it has only been one week since you had the injectors replaced and now it has started to missfire and stutter. Personally I would try to come sort of agreement with the service manager before the vehicle is booked in if you are concerned about a large bill.
    Does the car show any sort of engine management light when it is acting up? The reason I ask is my car had the same kind of symptoms but did not show up an EML, then it had a moment and the light came on so they could start to tie down where the problem was coming from. I think without a fault code it could get very expensive as any garage will just start to change things out until the problem is fixed.
    Keep us updated on it.
    Think at some point we are all going to need to have a 2.0TDi meet and all drive to the Audi UK headquarters with these cars!!
    Feb 2011
    7
    Thumbs down
    Quote Originally Posted by D8UGF View Post
    HI mate,
    yeah i will second that,now wouldn't that be a pr nightmare for them.
    my problems all started after injectors were fitted,although mine just cut out completely one day whilst driving it and i had to wrestle it to side of road as no power steering or brakes.
    since then its cost £0000's to put right,lovely cars,shame about the reliability
    May 2012
    Hi guys thanks for the response, car has no warning lights on at all so it might be had to pin point the problem but think it must have something to do with the injectors.
    Any way I rang Audi today to speak to service manager and was told he would call me back! No phone call at all so gonna have to ring Audi again in the morning and see what they say.
    Will keep you updated.
    Mar 2011
    North Wales
    210
    Mine's the same ever since it's had new injectors it takes a too long to start and splutters on tickover.
    Ran fine before they did this. I've lost all confidence in it and am thinking of switching to another make now.
    May 2012
    Booked back in at Audi on Monday will see what they say! Also given car a full service today to eliminate fuel filter, car still not running properly. Update on Monday.
    Jun 2011
    NW London
    141
    That makes three of us. I took mine in for a check. All injectors had already been done so it was just a Lift cam cover and read serials job. Now i have an ennoying hessitation at 1800 rpm, never happened before. Told em this, they eventually gave me a free diagnosis after writing to audi uk customer service and basically listed 8k of work lol... ****ing stealers!!! They even said they took it for a test drive, 0.3 of a mile excluding driving to the service area and back to parking bay (170m measured on mapmyride) exquates to 200m test drive! Good luck mate. audi whetstone was the garage i used and would not recommend.
    Rant over
    Cheers matt
    Audi A4 2lt 170 TDI Quattro s-line, B7, BRD engine code. Mods so far; cruise control, DPF delete, EGR delete, unicorn remap, B5 perches, RS4 rear arb, RNSE with SDS, 2013 maps with speed cams, aux in, powermax remanufactured balancer, Sachs SRE organic clutch and pressure plate with LUK flywheel. Mods to do; s4 break upgrade, glove box fridge perhaps...
    outsideline's Avatar
    Dec 2011
    181
    All you lads need to be looking in to premature wear on cam followers, thats my next road to take with audi uk. These are prone for wearing on the follower andthen wearing the cam, you need to check what your injectors are doing on idle and test for cam degree. Audi has a tolerance of 0.5 degree, mines badly worn at 4.85 degree!!!! Its giving me very bad idle problems and makes your injectors run all over the place!
    A4 b7 170bhp quattro | 210bhp remap from Rick @ UNICORN MOTORSPORT ( 07880558534) | DPF deleted | EGR deleted | 19" TSW Zolder 5 custom bronze wheels | rs4 grill | rs4 22mm rear sway bar | lamin-x head lights, fog lights, side repeaters | custom carbon wraped chrome window trims | E M Tuning LED conversion lights | genuine audi s4 rear valance | genuine audi s4 quad exhaust system to fit diesel | cupra R splitter | black audi ring badges | alpine headunit, hertz spl sub with JL audio amp |
    Rick @ Unicorn Motor Dev.'s Avatar
    Jan 2012
    Stockport, Cheshire
    748
    It seems that when injectors are recalled, that the rocker clearances aren't set properly. They need to be set using a DTI gauge and I don't think certain monkeys understand how to do it.
    Also, timing belt replacements often lead to incorrect cam timing
    Rick
    Unicorn Motor Developments. Bespoke Calibration and Remapping Services
    www.unicornmotordevelopments.com
    Jun 2011
    NW London
    141
    Hi rick. Cheers for the heads up, is it a big job to check and set correctly. Can't be arsed to go back to the stealers but might get local Indy to have a look if its not too mant hours of work.
    May 2012
    Update, car is now fixed touch wood, been for a long drive today and all seems ok!
    Basically took the car back to Audi said I wasn't happy they checked injectors all fine but found two faults, egr cooler and inlet manifold vacuum unit/actuator. Egr cooler leaking exhaust gas and vac unit completely gone not working at all. Audi wanted £607 to fix so said balls to that and went and picked it up, they didn't charge me a penny for checking it over and diognostics test. I went to TPS picket up a new vac unit and inlet gasket got it fitted today at Audi motorspost in clayton at a grand total of £70 they checked it over and said egr cooler was ok and car now runs fine not missing very smooth all for a £10 vac unit very happy again now.
    I must say a big thanks to Audi Motorsport for there help and to be honest Audi Blackburn were pritty good didn't charge me and also showed me what was wrong with the car, hope this helps any one.
    And I also cleaned egr valve and gave full service so running sweet now.
    D8UGF's Avatar
    Oct 2006
    Lanark
    107
    Good news mate, hope it stays ok for you. I had the entire manifold replaced under warranty and the lack of power at motorway speeds was resolved. In my case the plastic diaphram inside the manifold had broken and is part of the entire assembly which was changed under warranty.
    Dougie
    Lee Applin
    hi can i check to see if mines due any recall work somehow?
  1. Audi A4 B7 2.0 TDI PROBLEMS PROBLEMS PROBLEMS.... HELP!!!!
    By raffhussain in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 8th May 2014, 01:42
  2. Audi A5 Convertbile 2.0 tdi s-line clutch problem ?
    By Audi Dynamik in forum A5/S5/RS5 Forum
    Last Post: 20th February 2012, 07:48
  3. DPF removal on Audi A4 (B7) 2.0 Tdi 170 Quattro Avant
    By Holywood in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd July 2010, 19:14
  4. Audi a4 tdi problem
    By mikemyres in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 29th October 2007, 23:06
  5. 170 tdi problems
    By motorbikez in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th July 2007, 19:37
