Chris NottMonster Motorsport
    marky67's Avatar
    Feb 2011
    Solihull
    56
    Cleaning EGR valve on 2.0 TDI (170) Query
    When I was cleaning out the EGR valve (removing all carbon etc) I noticed quite a bit of oil on the inside of the inlet pipe.
    This made the carbon soft and sticky.....
    I assume this oil originates from possibly the turbo seals?
    Currently not putting an excessive amount of oil in.
    Performance & economy have improved since cleaning.
    Question is: Has anyone else noticed this when cleaning out the EGR valve?
    Should I be concerned that it is burning a bit of oil his way?
    A4 2.0 TDi 170 Quattro S Line
    Phantom Black
    Sep 2008
    56
    I shouldn't worry they all have some oil in the induction system.
    The crankcase emissions discharge into the turbo inlet ducting, although they go through some oil separation first the hot gasses themselves contain oil vapour which condenses when passing through the intercooler hence you will always find the egr and inlet wet with oil.
    marky67's Avatar
    Feb 2011
    Solihull
    56
    Thanks "c4a5er" that's good to hear.
    I was just a bit concerned 'cause I was not expecting it to be wet..... and had thoughts that the turbo was on it's way out.
    Phantom Black
  1. Guide for cleaning EGR on a 1.9 TDI....
    By DALE_AVANT in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st April 2012, 18:58
  2. 2.0TDI 170 (BRD) - injector cleaners, EGR cleaning, MAF cleaning.
    By brixo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd June 2011, 16:10
  3. EGR valve on a 2006 170 bhp s-line
    By TURBOTRONICS in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th June 2011, 17:27
  4. Cleaning EGR Valve?
    By benw123 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 24th January 2008, 19:26
  5. CLEANING EGR VALVE-QUESTION-
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 11th December 2006, 00:33
