Badger5AH Fabrications
    Apr 2012
    2005 A4 Avant 2.5 TDi SE Heated seats
    Hi
    New to Audi A4 & new to the forum...
    I have recently purchased an A4 Avant SE which has had a fair few mods along the way, one of which is full Alcantra trim and front Recaro heated electric seats.
    The heated seats do not appear to work and the heater controls on the dash do not light up when rotated..
    I'm not sure if the heater controls are a mod or original to the original SE spec of the vehicle and whether the seats are heated or not...
    Any info gratefully accepted....
    27,121
    Remove the climate unit & check if it has associated wiring 1st, also check under seats on connectors & see if any wires dont have matching pins on floor connector.
  1. 2005 A4 Avant 2.5 TDi cambelt change
    By strapkass in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th May 2012, 13:41
  2. Heated Seats replacing non Heated Seats
    By Diesel Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2012, 10:50
  3. Replies: 0
    Last Post: 27th October 2011, 16:30
  4. Stereo, heated seats, tempreture sensor problems on my tdi cab
    By dhillon884 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd February 2010, 10:10
  5. Advice on 2005 A4 3.0 Tdi Avant
    By danregs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th January 2010, 22:09
