Volks AutosSky Insurance
Results 1 to 12 of 12
    Jan 2012
    Cambridgeshire UK
    26
    2.0T flat spot, helf needed?
    Hi guys,
    I have a 2005 2.0T Quattro that has developed a flat sopt at around 4500rpm. I haven't had a chance to get fault codes checked yet. I have had a quick look and found that each coil pack pushed back in bit but thats all that i could see. Has anyone had this problem? Is there anything else i should check?
    Tim
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    Visit craigcull's Youtube Channel
    Hi mate, check the diverter valve, when worn they tend not to hold boost. But it will probably bring up a fault code aswell.
    Mine was the same. Or possibly check the condition of the plugs.
    Jan 2012
    Cambridgeshire UK
    26
    Thanks craigcull i'll have a look at the diverted valve and see what condition it's in. I'll also go and see how much a new one is.
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    There about £56 from Audi mate.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    the DV dont always cause a light on the dash
    and the car would feel flat as **** not just at 4500 rpm
    but worth checking
    APAutomotive's Avatar
    Shark Performance Shropshire
    Mar 2012
    Telford, Shropshire
    76
    Is the car mapped?
    craigcull's Avatar
    Oct 2011
    Leeds uk
    989
    mine didnt bring the light on, but still logged a code.
    Jan 2012
    Cambridgeshire UK
    26
    Hi guys,Took the diverter valve out last night and the diaphragm is torn! I have ordered one for £52 and it's coming tomorrow. I'm still going to check for fault codes this weekend when I can get access to my father inlaws computer.
    Jan 2012
    Cambridgeshire UK
    26
    Here's my old diverter valve!!
    Apr 2012
    NTH Lincolnshire
    55
    I am tempted to look at mine sooner rather than later as my 2.0t quattro seems a little low on grunt.
    My old 1.8T Passat seemed quicker.
    How long a job is it , to take out and put back.
    Brad.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    About 15 mins
    Jan 2012
    Cambridgeshire UK
    26
    I have been using the car for a few days now and there is no flat spot anymore. I stills feel not as quick as it did so i have now check for fault codes and this is what i've got.
    012555 - Low Pressure Fuel regulation
    P310B - 008 - Fuel Pressure Outside Specification - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 136
    Mileage: 93543 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1309 /min
    Load: 28.2 %
    Speed: 2.0 km/h
    Temperature: 0.0°C
    Temperature: 0.0°C
    Absolute Pres.: 1030.0 mbar
    Voltage: 14.478 V
    012600 - Intake Manifold Runner Control
    P3138 - 008 - Regulation Deviation
    Freeze Frame:
    Fault Status: 01101000
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 99156 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3721 /min
    Load: 29.4 %
    Speed: 80.0 km/h
    Temperature: 85.0°C
    Temperature: 15.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.224 V
    008200 - Intake Manifold Flap; Bank 1
    P2008 - 001 - Electrical Malfunction
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 99156 km
    Time Indication: 0
    Freeze Frame:
    RPM: 3717 /min
    Load: 29.4 %
    Speed: 81.0 km/h
    Temperature: 85.0°C
    Temperature: 15.0°C
    Voltage: 14.224 V
    000665 - Boost Pressure Regulation
    P0299 - 002 - Control Range Not Reached - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 0
    Fault Frequency: 1
    Mileage: 99239 km
    Time Indication: 0
    Freeze Frame:
    RPM: 4597 /min
    Load: 85.1 %
    Speed: 99.0 km/h
    Temperature: 87.0°C
    Temperature: 31.0°C
    Absolute Pres.: 1010.0 mbar
    Voltage: 13.970 V
  1. Flat spot
    By audi_a3_turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2011, 09:25
  2. flat spot
    By otis_b in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 2nd December 2007, 23:05
  3. S3 flat spot???
    By gurry in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2007, 15:42
  4. HELP NEEDED! - Flat Spot/Hesitation/Misfire
    By jdp1962 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th March 2007, 07:11
  5. S3 flat spot?
    By azures3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th May 2004, 07:28
