Volks AutosChris Nott
Results 1 to 8 of 8
Thread: heat loss
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,910
    heat loss
    2005 B7 tdi
    temp at 90 checked in vcds all ok
    no fault codes
    very little heat through vents all flaps ok etc
    gets upto temp as normal not slow
    any ideas ?
    TIA
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    Yep, your heater core is either full of crap or on it's way out. I had the same problem but couldn't get both tubes off the heater core so ended up flushing the whole coolant system and refilling. It worked. Refilled with Audi G12++ bottles from ebay.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    bez101's Avatar
    Jul 2008
    7,910
    hmm when its up at full temp and hear turned on i get normal hot air
    withing a few mins its going cold again
    so turn it off for 5 mins back on and same thing heat then cold
    ****in thing
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    That's what I had. It may be you have some air trapped in the system.
    Nathan
    26,716
    If you set the air to different directions to say feet, face, screen, does it then blow hot in any of those positions, wonder if its a flap issue, do a basic setting to reset the flaps, but strange blows hot then cold afterwards.
    bez101's Avatar
    Jul 2008
    7,910
    1st thing i did vcds and checked all flaps
    all ok
    im gona try bleeding it and then flushing the heater
    26,716
    Then I would have to agree atm, thats your best way forward for now mate, hope its an easy fix.
    raffhussain's Avatar
    Jul 2011
    Bradford
    73
    all ok
    defo heater core needs flushing. i has the same problem. would start warm and the cool down. it happended to me in winter and it was ****ing freezing. lol. flushed the heater core and took for a drive and boom heat. no let me down since. give it a try, nothing to loose. Hope you get it sorted
    CURRENT CAR: AUDI A4 B6 1.8T QUATTRO SPORT
  1. Heat
    By markos72 in forum Movies
    Last Post: 18th May 2012, 16:17
  2. Heating stops giving out heat .. after 10 seconds or so it will give out heat ???
    By jay786 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2012, 18:30
  3. power loss in heat!
    By DTM1 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th May 2010, 17:16
  4. The Heat is on?
    By AUDIDOO in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th October 2003, 11:02
  5. S3 Heat
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2003, 20:44
