AH FabricationsVolks Autos
    AjM
    AjM's Avatar
    Living in Blissful Ignorance
    Jan 2007
    Torbay, S.Devon
    295
    Xenon Change on a B7?
    Hi, I need to change my xenon bulbs on my 3L TDI and to say there is not any room is an understatement. I think the way to go is to take the headlight out, anyone no how to do this?
    Ant
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Bumper off job on the B7 to get the headlights out.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    AjM
    AjM's Avatar
    Jan 2007
    Torbay, S.Devon
    295
    You have to take the bumper off to change a headlight? I have heard it all now, the more I learn about this car the less I like it...
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,535
    Quote Originally Posted by AjM View Post
    Yes.
    The B7 was a cosmetic tweak of the B6 - the B6 was designed with servicing in mind so you could change all the bulbs (provided you have small hands and/or don't mind a bit of pain) but when the stylists were let loose on the front end redesign to create the B7 they totally ignored the need to be able to replace bulbs without having to remove major components.
    You even have to remove the wheel arch liner (and it's easier if you remove the wheel) to replace the front indicator bulb on the B7.
    May 2012
    i changed my xenon bulbs on my 2.0 tdi without removing the bumper, i removerd the airbox on the drivers side and power steering bottle on the passenger side, although ive not seen a 3.0 engine bay so im not sure if its the same
  1. Xenon bulb change Pre-facelift
    By rob irl tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th February 2012, 09:25
  2. Change xenon bulbs.
    By snusken in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th January 2012, 09:01
  3. Replies: 41
    Last Post: 22nd February 2010, 11:31
  4. xenon bulb change
    By dollface in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th November 2008, 17:59
  5. Xenon Headlights - Sidelight change
    By imported_ChristianF in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th March 2005, 20:34
