Chris NottEM Tuning
Results 1 to 7 of 7
    Dec 2011
    Glasgow
    195
    Audi cab Bluetooth microphone
    Hey everyone
    I'm in the process of retrofitting a Audi bluetooth module
    I've ordered and picked up today the mic unit that sits behind the centre light in my A4 B7 cab
    The mic is different from the more common flat mic there are 2 mic heads which fit into holes either side of the light unit
    I was expecting there to be just 2 wires a positive and a negative but the connector on the end is a 4 pin connector and the 2 mics are wired independently from eachother
    Im sure I rember reading somewhere ages ago that one of the two is for the Bose unit but I think I might of
    Imagened it
    Just thought I'd ask on here before I go diving into elsawin if anyone knows off hand how the mics are connected
    Any help would be much appreciated
    If not I'll get stuck into elsawin
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    27,114
    You only have 1 mic for the BT & it pushes into a pre-determined hole in the plastic assembly, there maybe ultrasonics in the light assembly aswell, you sure you ordered the correct part?
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    Sounds like he might have the TT part - which has the Bose and phone mics as a single assembly.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Dec 2011
    Glasgow
    195
    Hi guys
    Thanks for your input I have now worked it out after getting my laptop out and studying elsawin
    I have got the right part and yes there are 2 holes in the interior light for the microphones
    There are 2 mics one is for the the Bluetooth module and the other is for the Bose system (for monitoring I guess)
    I've made the wiring loom up for the module now the only other question that I've got is I guess I tap into the power connections can H and can L and k line by soldering the new cables onto the existing wires ? That are in the quad lock connector
    Mods
    Full VCDs
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,525
    mine pluged stright into the BT unit
    Dec 2011
    Glasgow
    195
    Cheers bez
    Ive got the 52 pin plug that plugs into the BT module I'm just refuring to the other end where it connects to the quad lock adapter at the back of the HU I've got the crimps that go into the connectors but the CAN wires ect are already used so I'm guessing I just solder the new BT wires to these
    Mods
    Full VCDs
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Quote Originally Posted by Gazthesparky View Post
    Cheers bez
    I cut the plug off the end on my mic and soldered them to the two wires that come off the loom off the back of the BT box, works perfectly, routing the cable down the door pillar is fun, just done an S4 cab, the roof lining has a lot more screws and nuts holding it on than my saloon. Picked my mic up for £9.99 plus P&P online.
    2008 A5 3.0TDI
  1. DNC microphone
    By paul1965 in forum In-Car Entertainment
    Last Post: 4th December 2011, 13:47
  2. Standard Audi microphone for phone kit
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th December 2009, 17:10
  3. SDS Microphone retrofit - non bluetooth.
    By BigRD in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 10th December 2008, 16:07
  4. Bluetooth Microphone
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th March 2008, 11:44
