Results 1 to 9 of 9
Thread: MFSW again,!
    Nov 2011
    Newcastle upon tyne
    31
    MFSW again,!
    Right nearly got all the bits together for my retro fit (so i thought) .So I now have 2 x cruise stalks 2 x dis stalks (avant) and 2 x slipring (although one has a broken tag ).
    Now the scm I ended up with is part no 4 FO 953 549 A ( Q AND R are now superceeded by A ) which I presume is from an A6 which had flappy paddle mfsw.
    when I test fitted it all up ( but not coded) I lost all functions from the wiper and indicater stalks,( I thought it could all be pre fitted before coding and all existing functions would remain ) now is thier somthing needs disabling in this module or is no good and I need the 8 E0 953549 A module ?
    any help great fully recieved.
    retro fit is on my 55 2.0 tdi s-line avant.
    A4 S-LINE AVANT 2.0TDI DOLPHIN GREY.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,147
    I would reckon you need the 8E0 one. When you retrofit MFSW and cruise, all your stalks will work apart from the MFSW controls (sometimes) and the cruise.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    26,716
    Its not showing the R superceded to the 4F0 at all.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,911
    you have something wrong wipers etc should still work
    and how much for your spare cruise stalk ?
    Nov 2011
    Newcastle upon tyne
    31
    typo error on the 4FO I meant on the 8E0 so my local parts department told me.
    as for the stalk don't know what the going rate is so make me an offer ?
    any one in or around Newcastle that could do the coding for me.
    bez101's Avatar
    Jul 2008
    7,911
    Quote Originally Posted by roblane65 View Post
    oh come on i cant be both buyer and seller
    Nov 2011
    Newcastle upon tyne
    31
    just had a quick check on fleabay and £20 seems about the going rate,+ a few quid postage unless you can pick it up.
    bez101's Avatar
    Jul 2008
    7,911
    im down in sheffield i can direct transfer
    does it have the 2 screws with it
    Nov 2011
    Newcastle upon tyne
    31
    sure I can sort a couple screws.pm me a contact no or email and we'll sort it out tomorrow evening.you'll need the lower cowl as well mine cost just over £30 from audi.
  1. Changing MFSW to DSG MFSW Help Please!!
    By Dannykn9 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th November 2011, 17:55
  2. mfsw for s3 8p
    By djlazyp in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th February 2011, 14:26
  3. mfsw
    By sbhoy17 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th May 2010, 23:38
  4. Non-MFSW to MFSW - 3-spoke wheel in B7 S4
    By pdt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th January 2010, 15:31
  5. Which MFSW?
    By 3.2 Ju in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th August 2009, 10:50
