Sky InsuranceAH Fabrications
    Dec 2011
    139
    Left Parking light bulb failure warning
    Hi
    On my A4 (05 plate) i've had a 35w HID xenon aftermarket kit fitted for the last 7 years (dipped beams only). About a year ago, i started to get left parking bulb failure even though the bulb was fine...however this seemed to be a temporary glitch and after a month or two never got the warning again. Last week i got a new 55w HID kit fitted (replaced 35w kit) and the dreaded parking light warning has returned even though the bulb is fine. Will replacing the left parking light bulb fix this or does this indicate something more serious?
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,186
    Change the bulb. I have had a warning for a while, on off. Led bulb and was fine,turns out if was loose is the holder. Check the front side light next time you get the warning and see if it working..
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
  1. Rear left parking bulb Warning...
    By DJ-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2012, 01:20
  2. Brake Light Bulb Warning - After Bulb has been replaced !!!
    By silversurfer in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th January 2012, 11:47
  3. brake pad warning light even though the pads have loads left on them
    By DOLPHIN DIESEL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2011, 13:53
  4. Brake Warning light, how long left?
    By Trigger in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2009, 01:28
  5. Bulb failure light on S3
    By s3_rob in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th June 2007, 23:53
