Sky InsuranceEM Tuning
    Apr 2012
    96
    Front bumper alignment
    Is there adjustment on the front bumper as mine just isn't right ...lines up everywhere except in one spot between the bonnet and n/s headlight and top of grill...also headlight isn't sitting perfect..so reckon at
    somepoint the headlight has been replaced...badly..any ideas
    alpesh26's Avatar
    Mar 2011
    264
    This happened to my car after it went in for headlamp adjustment. There is some black adjusters on the bonnet that are about the size of a penny. Just screw these in and out until it looks right. You won't get it spot on because the headlamp has been moved but it will look a little better
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    Apr 2012
    96
    I've had a look at the headlight as well but I can't get that right either I can adjust it closest to the grill but can find the adjustment or fixing bolt nearest the wing nearest to the indicator??
    Jun 2011
    NW London
    141
    hi have these saved in my favourites from previously adjusting my bumper, hope it helps
    DIY: Front Bumper Removal
    http://www.audizine.com/forum/showth...umper-removal)
    A4 B7 Bumper adjustment
    cheers
    matt
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,930
    as above remove bumper
    adjust till right then refit bumper pain in the arse tho
  1. Front alignment specs
    By tinka in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 11th April 2012, 12:40
  2. Front and Rear Wheel Alignment
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th May 2011, 18:19
  3. front alignment...do i need full gas tank
    By shamrock in forum General Automotive Chat
    Last Post: 2nd August 2010, 20:44
  4. Replies: 0
    Last Post: 8th September 2009, 12:03
