Volks AutosEM Tuning
    alpesh26's Avatar
    Mar 2011
    264
    Engine Judder, help!
    I've got a weird engine judder from my 1.9TDi. In 5th gear at around 1800-2100rpm under heavy acceleration, the car feels like its in the wrong gear and starts to judder, the gear stick also starts to wobble. It sometimes does the same in 4th at the same sort of rpm range. I've also noticed a drop off in performance, it doesn't seem to want to go.
    Today I cleaned the EGR valve, inlet manifold, MAF, intake valve (is this the same as the throttle body - i'm not mechanically minded!!) and hoovered out the air box because it was full of leaves. I replaced any gaskets/O rings I took off to eliminate any leaks. I'm still getting the judder even after all this cleaning. The only benefit I got from it is a quieter idle and slightly better throttle response but its still not like it used to be. The car was remapped about a year ago and has been running fine since.
    The EGR was caked in carbon as was the intake manifold, i'm surprised it was working in the state it was in!
    Have any of you guys had any symptoms like this and what was it or what could it be? I'm thinking it could be either the turbo, boost leak, injector or flywheel (the clutch is at normal biting point and replaced about 30k ago so i dont think its that).
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    May 2011
    Bournemouth
    55
    I'd say get the actuator checked to see if the VNT Mec on the turbo is working correctly. Then look at the N75 valve.
    Hybrid Turbo - De-DPF - Weitec Coilovers = Fun!
    alpesh26's Avatar
    Mar 2011
    264
    Bit of an update on this, i drove the car this morning to work and the judder was gone. Maybe there was some carbon left in the system which has now cleared out. Its is more responsive but not as much as it used to be after the remap so I still think something is sticking/not working properly. At least i've ruled out its nothing to do with the transmission.
    Cheers for the reply Adam, i'll get the actuator checked out. Would this have to be done at a garage or is it something that can be done at home? Think it can only be the turbo that's causing the loss of performance now
  1. Engine judder on startup only
    By leecool in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th July 2013, 22:55
  2. Engine 'judder' / hesitate on acceleration. help!
    By sc_001 in forum Classic Audi Forum
    Last Post: 21st September 2010, 03:19
  3. [A6 2.0 tdi] engine judder
    By jaskol1 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 12th January 2010, 17:10
  4. 1.6 engine judder?!?!?!?!?
    By cameronm in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th September 2009, 00:03
  5. Engine judder when idling
    By Nevdog02 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th November 2007, 18:08
