remove the front panel, undo pipes and wires, remove the exhaust front pipe/cat, undo all the bell housing bolts, get your engine crane on the lifting hoops, take the weight, and undo the engine mountings, lift it up a touch and wiggle it off the gearbox.
when going back in undo the slave cylinder for the clutch and push it out of the box. otherwise it'll fight your trying to wiggle it back on.
