Monster MotorsportEM Tuning
Results 1 to 18 of 18
    Mar 2012
    Essex
    118
    EGR valve location on 3.0 v6 tdi engine
    Hi all, I want to clean my EGR valve to see if it helps with some cold running issues I have at the moment.
    I've searched posts for this, but can't find any answer as to where the damn thing is located on the 3.0 v6 engine!
    My best guess is that it's in the middle towards the front, but I'm not sure, any ideas? Pictures would help if possible.
    Also, how easy is it to remove, clean and refit, has anyone done this before?
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    I don't know, but I'm having it removed at a garage on Saturday so can tell you after that...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Mar 2012
    Essex
    118
    Are you having it replaced or completely removed and blanked off?
    Any help appreciated if you can find where it is!
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    I'm just having it disabled. Little point in having it blanked off or removed as if it's delected from the ECU code it remains closed permenantly. Then if it needs to be re-enabled (for any reason), it should just be a case of re-instating the code (after cleaning it most probably). I'll keep you posted on Saturday
    Mar 2012
    Essex
    118
    ok cheers
    Tiptronic
    Jun 2010
    Nottingham, UK
    823
    Hi Jas, sorry for the late reply, had a hectic weekend. I didn't manage to find the exact location of the EGR as it was just disabled in the ECU and not removed. Sorry I could be of no help. If you take the cover off the engine and follow the piping from the turbo it should be fairly easy to find...
    Feb 2006
    derby uk
    39
    It is between the cylinder banks, attached to the egr cooler next to the right hand inlet manifold.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,679
    A picture would paint a thousand words.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Jul 2007
    London
    3,246
    Look for the shiny silver actuator with a rubber hose going to it...
    FOR SALE:
    Mar 2012
    Essex
    118
    Cheers guys, I think I know where it is, and it looks almost impossible to remove!
    Feb 2006
    derby uk
    39
    not as bad as you think to remove - get a copy of the elsa off the bay and it shows you- i can't work out how to post pictures on the forum.
    Jun 2012
    Hi, I need some help guys.
    I keep getting these fault codes;
    2 Faults Found:
    4807 - EGR System: Insufficient Flow
    P0401 00 [096] - Short to Ground
    5215 - Fuel Rail/System Pressure: Too Low
    P0087 00 [032] - Cannot Be Tested at this Time
    Car has done 100k miles/160k km, and I'm thinking it is EGR valve that need to be cleaned. What do you think?
    Engine bay looks like a rats nest and I'm not really sure where to look fot the EGR valve
    I hope someone wiser can show me, here is the pic of engine:
    carl-1968's Avatar
    May 2012
    Nottingham
    457
    I got mine blanked and deleted from the ecu roughly located r/h side towards front of engine, aproxx 1 1/2 inch dia braided pipe between exh and inlet, i'll send you a pic if you pm me as i still cannot post pics or vids on here!
    Carl
    gupsterg's Avatar
    Jun 2012
    Lurking over a keyboard!
    279
    Quote Originally Posted by mongs View Post
    2 Faults Found:
    Perhaps no use now as you posted so long ago but I came to this thread via a google search and thought perhaps place the info for if another in future turn up...
    Yours to me looks like the later engine code CAPA 3.0 TDi V6 (same for later 2.7 TDI engine code CAMA & CAMB)
    Red box is electronic EGR control valve... green box is the vacuum operated EGR cooling flap solenoid...
    Mar 2012
    Essex
    118
    I blanked mine, but when the car went in for some work I got them to remove the EGR and clean it - but it was already clean, so I unblanked it again. Getting to the location of the EGR was a bit too much for me.
    Mar 2012
    Essex
    118
    mongs - it might be worth blanking it first to see if it helps, it's an easy job to blank it. It will bring the engine light on though.
    Jun 2012
    I did change the EGR valve, seems like the problem is (almost) gone. I've driven at least 10tkm with it and only once have gotten the same error code (no MIL light)
    The EGR I removed, wasn't busted or clogged but the replacement valve has worked better (error-free). Maybe it was electrical faul in the EGR, since it the flap is PWM-controlled..
    gupsterg's Avatar
    Jun 2012
    279
    Quote Originally Posted by jjmurphy21187 View Post
    Quote Originally Posted by carl-1968 View Post
    How much did you guys pay for EGR delete from ECU?
    TIA
    G
  1. EGR Valve location on B7 2.0T Petrol
    By wyliss in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 21st February 2012, 20:45
  2. EGR Valve and Engine Breather
    By dinothetiger in forum Diesel forum
    Last Post: 16th January 2011, 11:37
  3. 2.0 TDI EGR VALVE
    By X2JPH in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 23rd February 2010, 11:08
  4. 2.5 TDI - EGR Valve
    By hodgy0_2 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th September 2009, 13:11
  5. A4 190ps (BEX engine) Diverter Valve location
    By imported_bubstar in forum Tuning
    Last Post: 24th January 2005, 22:01
