Sky InsuranceChris Nott
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Grinding Rubbing Noise when foot offf accelerator
    I've noticed this over the past few months but when doing between 20-30, if I take my foot of the accelerator quickly there is a rubbing/grinding noise that lasts for about a second. There isn't any problem with performance and doesn't come on when accelerating. The more sudden you remove your foot, the worse it is.
    Any ideas?
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
    D8UGF's Avatar
    Oct 2006
    Lanark
    107
    Stab in the dark here Wrath as a noise could be anything I supose, at one of my many visits to Audi the technician told me that the noise I was hearing is the turbo spooling in the opposite direction to its normal direction between gearchanges, it is part of the design apparently. That is for a 2.0tdi 170 tho, not sure what engine your cars got mate.
    Dougie
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Quote Originally Posted by D8UGF View Post
    Cheers Dougie. I've had a look on the internet and there's a few posts about it being the wastegate and a couple of other posts to say Audi techs advise leaving it alone and it isn't a problem. It just sounds awful and wasn't sure if it was a sign of something going wrong. My engines a 140 but can't imagine too much difference with the 170.
    Nathan
    Nathan
    Jun 2012
    Hi Wrath
    I have a 2.0tdi 170 which does exactly the same. The noise sounds like brake pads grinding on the discs. When I took it back to Audi the mechanic told me that all a4 diesels make this noise. I think i'm being fobbed off, but can't find anyone who will offer a diagnosis.
    Just wondering if you have had anyone tell you what the symtoms might point to?
    Let me know if you do.
    S
    Mar 2013
    32
    Old post but I'm hearin the same noise and wondering if its a problem or just supposed to be there? Did any if you get good answers as to what te noise is or wether its normal or not ? Just had June at a German specialist garage and they said they cudnt hear anything wrong and no codes but te noise I hear sounds rough! And sometimes flutters in low gears
    Quote Originally Posted by seroquel View Post
    Hi Wrath
    S
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,148
    Still running and the noise still there. No lights on dash and everything else seems fine.
    Nathan
  1. Popping sound when taking foot off accelerator
    By NCRAW in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2012, 23:30
  2. Grinding/ Rubbing sound on cornering?
    By slydog18 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th February 2012, 21:21
  3. Audi A3 1.8T (8l AUM Engine): Strange noise - grinding/rubbing noise..
    By pangsterA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th December 2011, 21:01
  4. AIR LEAK AFTER TAKING FOOT OFF ACCELERATOR
    By rogerout in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2010, 13:54
  5. rubbing/grinding noise
    By mintie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 18:56
