Badger5EM Tuning
    Jul 2011
    Teesside
    327
    Problem with rear led lights
    OK so Ive had the rear led lights on for a few months now with no issues. When I first fitted them I noticed that they only worked when either the lights where on but no key was in the ignition or if the engine was running. If I tried them with the key in and the ignition on but no engine running then 3 leds would fail after a few seconds on the passenger side cluster.
    I could live with that so I was happy enough......
    Tonight Ive noticed that now they only work if the engine is running. If the engine isn't running the same 3 leds fail after a few seconds.
    I really need some advice as sending these back to the supplier, ie the USA would be a right expensive ball ache......
    Any advice guys?
    Jul 2011
    Teesside
    327
    My car is due for a MoT in a few weeks time. Will this make it a fail? Or do they test the lights with the car running? Not all the leds go out, 3 leds out of I think about 8 go out with 5 staying on so there is still light so..........
    Aug 2010
    1,540
    i think....... with led lights, 50% of the individual light sources need to work. so youd have a pass and advise.
    im not sure tho, if i was at work id have to look in the manual......
    maybe another tester will confirm??
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,433
    if there from the usa
    i wouldnt bother sending them back
    ull have to pay postage then import tax when they send them back
    Jul 2011
    Teesside
    327
    Right so quick update....
    Used the car tonight, got home and thought id check the lights and they worked? No engine running, just the switch on and no leds failed.....
    Im wondering could it be a power thing? The car was stood yesterday for a day or two when the lights failed, now there working could it be because ive used the car? The batteries not failing but leds are a queer thing sometimes so?
  1. B8 led rear lights for a B7
    By JDM82 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st October 2011, 20:52
  2. Replies: 6
    Last Post: 23rd August 2011, 12:48
  3. Rear LED lights
    By TOON FLYER in forum Parts Requests
    Last Post: 6th May 2010, 21:20
  4. LED rear lights..
    By Mikey170 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2009, 12:17
  5. LED Rear Lights on an S3 8L ?
    By dares_uk in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th December 2008, 19:47
