Chris NottAH Fabrications
    Apr 2012
    A4 Cabriolet soft roof problem..
    Hi. i have upload a video with the fail on youtube Audi A4 Cabriolet soft roof problem / A4 Cabrio verdeck problem - YouTube
    and i have manual take the roof up and down for reset switches..... but no luck :-(
    when i turn the ignition on the roof warning light will flash 10 times and then stop
    i have vcds to read and clear error.
    Torsdag,26,April,2012,18:48:04:42057
    VCDS version: NEZ 908.1
    adresse 26: El.tagbetjening Forklaringsfil: 8H0-959-255.lbl
    Styreenhed reservedelsnr. : 8H0 959 255
    Komponent og/eller version : VSG B6 CABRIO 6184
    Software kodning :
    Forhandlernummer : WSC 00672 785 786632
    2 fejlkoder fundet
    02000 - Kontaktposition
    008 - Urealistisk signal
    01986 - Føler til spændbøjleposition - kaleche (G356)
    Regards Carsten
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    826
    Don't know anything about codes, but since you've had no other responses... It looks like the motor is struggling to open the hood cover, then once it's reached the open position is just falls back down again. Have you followed the repair guide for the motor in the boot? Maybe check to see if the support struts are leaking and hence not providing enough force to hold the cover open?
    Not 100% sure if this will fix your problem but it might be worth investigating: Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
  1. Audi A4 Cabriolet Soft Top/ Roof / Hood Motor Repair Guide
    By VagPro in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1 Day Ago, 12:27
  2. A4 Cabriolet Roof Problem...
    By A3 Sport in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 30th September 2011, 20:54
  3. A4 cabriolet roof problem.
    By pbranson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th September 2011, 20:30
  4. Cabriolet Roof Problem - Please Help!
    By StuartC in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:22
  5. Audi Cabriolet roof problem
    By RoStar in forum Classic Audi Forum
    Last Post: 28th March 2004, 18:47
