    Jun 2007
    Norfolk
    66
    3.0 TDi just sorted a few fault codes
    been a busy morning, i had some fault codes on my car and i thought i should work through them
    First off was 2x glow plugs were showing faults so i changed all 6, some of them were heavily blackened, think i found the 2 suspect ones.
    Ran the car for a while, no fault codes showing yet, only took me about an hour to change them
    Also, while under the bonnet, thought i would clean out the air intake, i am so glad i did, there was lots of leaves and dirt clogged in the intake pipe from the grille!! i have a photo as i was shocked.
    Next the hood, top frame sensor was faulty. Looked on-line and they released a revised potentiometer for the cabrio, (£65 for something so small!!) however the hood works without any hesitation, so worth it!!
    Only a couple more to sort out, a PDC and alarm module faults, but i will get to them.
    Pleased these jobs are done now hopefully should get a few more MPG now, as i was only getting an average of 36mpg on a motorway run!!
    26,747
    Ah vcds is king
    Jun 2007
    Norfolk
    66
    it is ...
    Just need to get Elsa and Etka now..
  1. audi a3 8p 2.0 tdi 2004 fault codes, help!!!
    By chrisy t in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd January 2012, 12:16
  2. 2.5 tdi engine fault codes help please...
    By Kostas in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th June 2011, 02:53
  3. Issues with a3 tdi sportback..........fault codes......please help!
    By vw754 in forum VCDS (formerly VAG-COM) forum
    Last Post: 19th January 2010, 22:59
  4. 2005 A3 TDI - pile of fault codes
    By timcoupe in forum VCDS (formerly VAG-COM) forum
    Last Post: 18th September 2009, 12:46
  5. fault codes A3 TDI
    By Evstdi in forum Diesel forum
    Last Post: 14th February 2006, 11:35
