Badger5Chris Nott
Results 1 to 13 of 13
    Dec 2011
    Glasgow
    195
    Advice on egr valve
    Hi all
    I've got a a4 b7 2.0ltr TDI and I'm not sure If it's just my imagination or if the engine is vibrating and noisier than usual while stationary
    So I've read alot about cleaning the egr valve on the car so I'm going to have a look
    The cars only done 41 thousand miles but the previous owner ran it on supermarket fuel so think it might be caked up
    First things is do I need 2 new gaskets ?
    Then is it carb cleaner I clean it with
    And finally can I just check is this the valve in the picture and I'm guessing you undo the 3 Allen key bolts the 2 at the top and the 1 underneath ? Then undo the connectors and pull it out to clean
    Do you then just replace the gaskets and bolt it back on ? Do you need to rest anything using vcds ??
    Just got a few nerves as I don't want to try and fix something that's not broken and actually break it lol
    [/IMG]
    A4 B7 2.0ltr TDI Cabriolet
    Mods
    Puddle lights Illuminated cup holder Cd changer in glove box Interior lighting led upgraded
    Full VCDs
    Macdoon's Avatar
    Essex
    1,569
    Imagine that.... typed in egr valve in the search bar....wow an answer....
    Audi A4 B7 2.0 TDI PROBLEMS PROBLEMS PROBLEMS.... HELP!!!!
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Dec 2011
    Glasgow
    195
    Wow thanks I never thought of that how silly of me
    No seriousily I did search spent the whole day researching and even read that thread
    Was just asking for clarification as to the location and if in fact that was the egr valve that I'd taken a picture of because it looks different to picture I've seen of others
    Mods
    Full VCDs
    Macdoon's Avatar
    Essex
    1,569
    Gaz my mate is a mechanic, so i took it to him, he had mine off, cleaned out, new gaskets, back on 45mins (included us talking ****e and tea)
    Dec 2011
    Glasgow
    195
    Just been to halfords and the only carb cleaner they have is wynss carb cleaner can it says for petrol engins can anyone confirm if this is ok to clean my egr valve? Or is there a desiel versition
    Mods
    Full VCDs
    alpesh26's Avatar
    Mar 2011
    271
    it'll probably be fine as your not really cleaning the carb with it
    Audi A4 B7 1.9TDi SE | Auto Lights, Wipers & Dimming Mirror | Cruise Control | DIS
    Mod's so far: Ambient light, Cupra R splitter, 4300k HID's, Painted Brake Calipers & Hubs, Dice Electronics iPod & Aux, Leather Armrest, Interior, Sidelight & Number Plate LED's, Curry Hooks, Tie Downs, Ambient Footwell LED's, Footwell Lights, Shadow Chrome S-Line (RS6) wheels, Mudflaps, Votex Rear Diffuser, RS4 Rear ARB
    madstaff's Avatar
    Apr 2012
    74
    Wynns carb cleaner will be fine. If you could get 5 litres of brake cleaner that would be better as you can fill up a container with it.
    I filled up something like an old ice cream tub with brake cleaner, and let it soak, then got busy with an old paintbrush.
    A dirty horrible job!!
    Dec 2011
    Glasgow
    195
    Well I did it used the a Tin of the wynns carb cleaner. It hasn't made any noticeable difference to the car when it's just idleling it still shake and vibrates the valve was certainly caked in carbon and now I've got black hands to prove it couple of photos of before and after
    Before
    After
    [IMG][/IMG]
    So I'm not sure if the timing is out or it's miss firing so I believe u can check this with VCDS if someone could advice what I have to do to get these readings is be great full then if I could post the results up and if someone would be willing to look them over id be grateful because I haven't got a clue what is normal
    Thanks for the advice up to yet
    Mods
    Full VCDs
    Oct 2009
    166
    Gaz, I'm no expert but everything I've read on these threads leads me to believe the symptoms u are experiencing are the dual mass flywheel failing not an engine issue.
    My car does exactly the same, had the injectors replaced, cleaned the egr and will do the maf.
    Sure someone will know better who has had the flywheel replaced, worth doing some more investigation though?
    Audi A4 Avant TDI 170 S-Line
    1992 Saab 900 T16S Convertible
    Mar 2011
    North Wales
    210
    Mine does the same even though it had a new egr about 12 months ago and have only done about 4k since. Doesn't do it all the time though and I also see the rev counter moving which makes me wonder if mine is the dmf as I can't see how this would affect the actual revs.
    Would like to get it sorted though
    raffhussain's Avatar
    Jul 2011
    Bradford
    78
    mine does the same thing. Ive changed the DMF and clutch but that didnt help. also cleaned EGR, new MAF, New turbo. still the same. i read somewhere that these engines to vibrate on idle and its the way the engine is. im not convinced. its got to be something thats causing it. the rev counter on mine doesnt move but u can still feel the car shake.
    CURRENT CAR: AUDI A4 B6 1.8T QUATTRO SPORT
    Oct 2009
    166
    The revs dont fluctuate on mine either.
    Surely if the engine was at fault you wolud see the needle moving or hear a change in tone?
    My clutch is def on way out and will see about the dmf when it gets done.
    Wrath's Avatar
    Apr 2009
    North East, UK
    1,185
    I read they vibrate a little on idle although a few cars had this reduced by an ECU update apparently.
    Nathan
    Red Audi A4 B7 S-Line with Leather/Alcantara interior
    Current Mods: Painted Brake Calipers, Gear-driven oil shaft assembly, RS4 grille, Debadged, B8 MFSW, Cruise Control, RS4-style Fog Surrounds, Satin Black Cupra R Splitter, RS4 RARB, Clear Corner headlights, 2011 RNS-e, MTEC Drilled and Grooved Brake Discs.
  1. EGR valve
    By ScottD3 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd June 2011, 19:59
  2. EGR Valve help?
    By Maq in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st January 2011, 12:18
  3. EGR valve
    By banny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2007, 14:36
  4. EGR Valve
    By Caesium in forum Diesel forum
    Last Post: 17th February 2007, 10:46
  5. EGR VALVE REPLACEMENT-ADVICE-
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2006, 14:19
