Volks AutosAH Fabrications
Thread: Window???
    Feb 2012
    39
    Window???
    Alright lads am getting a draft cumming thu my dash,it cuming from the dash in the right hand corner. It sounds as if the window is open when I go past 60 av checked the seals on the glass and all ar fine ??????? Any ideas wats causing this and it's on my b7 a4
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,285
    I get it at high speeds,its from the air vents, if you turn them onto internal air recirc then it stops the draught and the noise.
    Sent from my HTC Incredible S using Tapatalk 2
    09 S4 3.0 Supercharged MRC Stage 2 remap 480BHP
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, plus loads of mods - SOLD
    Feb 2012
    39
    and how do you do that bud is that just by the switches on the air vents its self??
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,285
    By the switches, its the curved arrow button by the left hand temp control (from memory). Don't leave it on all the time though as can cause it to mist up sometimes as it then doesn't draw in fresh air from outside. Use if stuck in traffic also to avoid breathing in fumes.
    Feb 2012
    39
    Just had it on there mate didn't notice any thing, I can still feel the cold air cuming frm the corner of the dash on the right hand side next 2 the window screen
  1. How to replace them chrome window seals without taking out the window frame on a Audi
    By Turkster in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2012, 12:57
  2. Window help
    By brys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd August 2010, 20:39
  3. Window down and won't come up!!
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd January 2010, 17:51
  4. Window help
    By OllyS4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 25th March 2008, 14:02
  5. Window
    By migzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th June 2007, 22:54
