Monster MotorsportVolks Autos
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    brake fluid - just top up?
    Hi
    my brake fluid is below minimum, is it just a matter of topping it up or do i need to take it in to indy/dealers?
    ANDYTQ's Avatar
    Oct 2003
    Caerdydd, Cardiff, United Kingdom, United Kingdom
    925
    If its that low you need to check your pads they might need changing ,the level drops as the pistons move out more to compensate for pad wear.
    06 A4 AVANT QUATTRO 2.0T S-LINE SE,GARNET RED, RS4 REAR ARB,SPACERS ALLROUND,H & R SPRINGS,B5 PERCHES,A6 V8 RIMS.PORSCHE CAYENNE TURBO S SIX POTS .REVO MAP ,STATIS CATBACK EXHAUST,PANEL FILTER.
    Mar 2011
    112
    I would also check for a leak in the system. Check the pedal is firm by decaying servo by pressing pedal several times. Pedal should then be firm with no give. If it travels to the floor then definitely get system checked by someone who knows hydraulic systems as you may have a leak that could get worse very quickly and you would then have limited or no brakes.
    z1mma's Avatar
    Apr 2012
    Birmingham
    101
    brake pedal is really stiff not loose, brakes seem to work fine had them replaced about 6 months ago, after checking the brake fluid again i can see like a yellowy liquid below min and looks like clear liquid (water?) above max
    Mar 2011
    112
    Quote Originally Posted by z1mma View Post
    Brake pedal pumps up firm without engine running and doesn't move to floor, so hopefully you haven't got a leak. I doubt if the clear liquid at the top is water as oil floats on water so more than likely fresh brake fluid and the yellowy below min is probably aged brake fluid.
    As mentioned in an earlier post have you checked the pads as they may be towards minimum and need replacing hence why the fluid level is low. Always check the obvious things first.
  1. stupid clutch and brake fluid question..do i use the same fluid?
    By Rob_B in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd June 2011, 10:19
  2. Where to top up clutch fluid?
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2011, 15:19
  3. Just bled the brake fluid and replaced...Brake warning lights!!
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th December 2010, 01:05
  4. Braded brake line and brake fluid help.
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th June 2010, 08:23
  5. A6 brake fluid top-up
    By bircham in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 19th April 2006, 18:57
