Results 1 to 7 of 7
    Apr 2012
    96
    Dimensions of saloon front overhang
    Anyone know this please..also how much lower is a s line please
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,691
    Quote Originally Posted by Daz4311 View Post
    Are you referring to the distance between the centre of the front axle and the most forward point of the front bumper? If so, then a tape measure is your friend.
    I thinks it's about 20mm, but others may say something different.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    Apr 2012
    96
    I cart measure it yet As I haven't got the car yet
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,691
    If it stops raining, I'll go and measure mine. Out of curiosity, why do you want to know?
    Apr 2012
    96
    I've got a funny driveway and have caught the bottom of several bumpers in the past!!
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,691
    From the centre on the front axle to the most forward edge of the lower bumper lip is, as near as I can tell, 920mm.
    Hope that helps.
    P.S. You might want to consider reversing in. Although the rear overhang is probably longer still, the bumper lip is higher at the back than the front, so you get a better "departure angle".
    Apr 2012
    96
    Cheers for that fella ...will try reversing in when I pick the car up..maybe saturday!!
  1. B6 avant front wing same as saloon?
    By wafers in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 30th December 2011, 15:29
  2. S3 Front mount. what dimensions can i go to?
    By Luke S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th July 2011, 15:07
  3. Is the front end the same on a B7 cab and saloon?
    By dhillon884 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 2nd January 2010, 18:17
  4. S4/A4 saloon inner boot dimensions?
    By aidank1981 in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th June 2009, 14:49
