Badger5Chris Nott
Thread: B5 spring cups
    Mar 2011
    112
    B5 spring cups
    Hi .
    Just fitted 2 B5 spring cups to my 2007 2.0T FSi Quattro Avant and it sits a lot better now. I re used the rubber lower spring seats of the other cups but they are not a perfect fit into the B5 cup.
    My question to anybody who has also done this mod is did you also re use this part or did you use the B5 rubber and if you did does
    the spring locate correctly in the B5 rubber.
    Thanks for any help.
    Dec 2006
    494
    before and after photos?
    05 Audi A4 2.0T Quattro
    Black with a BIG wish list!
    Mar 2011
    112
    Quote Originally Posted by AudiSport View Post
    Sorry no pictures as was battling to get this done in a dry spell outside, but I'm sure if you do a search there are plenty to be found on the internet of before and after, in fact think i've seen some on Audizine.
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,139
    Visit Craig Cull's Youtube Channel
    Does this mod affect the wheel alignment?
    Mar 2011
    112
    Quote Originally Posted by craigcull View Post
    Personally I don't think so because of the way the suspension is designed. Others have said that they not had alignment checked and tyre wear was not affected. The only adjustment is toe in/out. There is no castor or camber adjustment apart from centralising subframe to even up camber on both sides. As I said this is my opinion, best to check with specialist.
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,139
    Thanks mate
  1. B7 Front Spring Cups
    By rizzini7 in forum For Sale/Wanted - Audi Parts
    Last Post: 4th February 2012, 20:17
  2. MOT FAILED - Coil Spring Fractured. Will Quattro spring fit A3 Sport?
    By shakt1 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th December 2011, 14:06
  3. Has anyone done the B5 spring cups mod
    By Macdoon in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th April 2011, 14:38
  4. ia after some 19" porsche cups any ideas where i can get some??
    By grays3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th November 2007, 23:09
  5. Which DV Spring?
    By Charlies604 in forum Tuning
    Last Post: 21st January 2006, 12:17
