Volks AutosEM Tuning
Results 1 to 8 of 8
    Apr 2012
    96
    Multitronic gearbox..anyone not had problems??
    Having just bought a 2.0t fsi sline with a multitronic gearbox..I'm panicing after reading all the bad stories so has anyone not h
    ad problems or got onewithout problems...please!!!!
    Feb 2012
    West Wales
    155
    Mother has a TDI auto and has had it for about 6 months - all fine so far.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,316
    I had a 52-plate (B6) 2.4SE multitronic, built before the upgrade to the 7-plate clutch set up. I had it for four years, during which I took the mileage from 54,000 to 87,000. I made sure the gearbox oil had been changed before I got it (it had) and I had a further oil change done whilst I had it (a wee bit early, at 72,000 miles). I also regular cleaned the torque sensors. Nothing broke on it all the time I had it.
    Maintenance is everything with these. The oil change every 40,000 miles is as essential as it possible to be.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs.
    viceroy's Avatar
    Aug 2011
    Johannesburg
    198
    I have a 2008 B7 2.0T multitronic and not had even a glimmer of a problem.
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    Mar 2011
    S E Kent
    218
    2006 1.8T- no probs here
    2006 A4 cab
    jakeA42T's Avatar
    Oct 2011
    Gravesend
    90
    2005-06 2.0tsline gearbox ECU went at 40k odd, it had the 7 plate clutch. I had the TMF changed and new ECU put on £1300 but drives perfectly now. This is the 1st and last auto i'm buying thats for sure.
    Audi A4 2.0T Fsi S Line Multitronic
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,927
    iv worked on many a multitronic all years high very high and low miles and non but 1 has had the problems
    you only hear the bad storys about them not the good
    but i would never own 1
    sidibear's Avatar
    Looking for Zombies !!
    Nov 2008
    Birmingham UK
    1,908
    2008 B7 Avant 85K, no problems but had the DMF changed and oil is always changed every 40K.
    JSD 2.59
    Synergy-Solutions
  1. Audi A4 2005 - Multitronic Gearbox Problems.
    By Ash4d in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th August 2010, 13:35
  2. Problems with A4 Multitronic Gearbox
    By purplecatqueen in forum General Technical / How To
    Last Post: 18th May 2009, 15:35
  3. multitronic gearbox
    Last Post: 19th April 2009, 10:43
  4. Multitronic Gearbox
    By terrysingh in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th September 2007, 20:31
  5. HELP multitronic gearbox!!!!!
    By Spannertail in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th April 2007, 16:55
