Volks AutosAH Fabrications
    northernlight's Avatar
    Sep 2011
    56
    TFSI Clutch Slip
    Just thought i'd run this one past the B7 oracles on here!
    MY 08 plate TFSI Quattro SE has 25k on the clock and has performed flawlessly in the 6 months that i've had it. However on a couple of occasions when accellerating at circa 60-70mph in 5th i have experienced a little clutch slip. Not really thought much of it, but not i've had the stage 1 AMD remap done i was in a similar situation on the motorway again yesterday and the same thing happened.
    It pulls fine in all lower gears, i'm just a bit concerned now that the clutch isn't up to the torque of the car.
    Anyone have any similar experience, thoughts on solutions?
    08 2.0 TFSI Quattro SE V2, Milltek RS4 system, RS4 ARB, AMD Stage 1 remap, Xenons, Valcona leather, RNSE, Eibach Pro Springs, Bose.
    Sep 2009
    worcester
    1,097
    my dtm was the same when i first got it, slipped at low revs in high gears, you could get it to last a bit longer if youre prepared to put up with it but i'd bite the bullet and get it done, do the dualmass flywheel at the same time too
    Sep 2009
    worcester
    1,097
    Sep 2011
    56
    Any ideas on cost of replacement and if i do decide to get it done is it best to go OEM again, or are there any better upgrades? (without having to sell a kidney).
    Sep 2009
    worcester
    1,097
    genuine parts and labour (not audi) £1000-1200 depending
    non genuine parts and labour £500-700 again depending
    its a big job and you could cut costs by not replacing the flywheel but its a risk most people dont take me included, after having your clutch done 6 months down the line your flywheel could let loose, not only do you have to go through the whole process again but you risk fudging your new clutch too which equals more money
    I fitted standard pattern bits but i suppose you could fit a sachs clutch if you really felt the need but the majority of people who have remaps run standard stuff, its not as if youre launching 500bhp at every set of lights
    sorry to ruin your monday
    Sep 2011
    56
    I think i'll see how it goes for now, it's only slipped 3 times in 6 months and only then for a split second whilst probably giving it too much beans at low revs in a high gear. Car has never been thrashed and i've never had a clutch go before, so 25k miles would be rather disappointing in a supposedly high quality car!
  1. Clutch slip or not?
    By scubadriver in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2011, 12:52
  2. CLUTCH SLIP!!!
    By panamadi in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st March 2010, 20:31
  3. clutch slip
    By s3ollie in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th March 2008, 23:45
  4. clutch slip?
    By mikerd4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd March 2007, 12:14
  5. Clutch slip?
    By batwad in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th February 2007, 14:19
