Badger5Chris Nott
    Jan 2012
    Falkirk
    19
    BRD Engine Number Location
    Hi All,
    Can anyone tell me where I can locate the engine number on the block ??
    Jan 2012
    Falkirk
    19
    Any takers on this, even with the engine out, I can't for the life of me see an engine number anywhere. Obviously a sicker on the cambelt cover but I would have thought that it would be stamped on the block.
    I may find it when I take all the ancillaries off.
    Sep 2008
    60
    The engine number (“Engine code” and “Serial number”) -arrow- can be found at the front of the joint between engine and gearbox.
    There was an image with this but posting permissions won't allow attachments.
    chrisa4quat's Avatar
    Sep 2004
    897
    Ring dealer. If its the original engine if you pm me with reg I'll get you number according to vehicle details
    Imola Yellow A4 DTM. Retro fit cruise and arm rest.
    Contact Admin to advertise please
    Jan 2012
    Falkirk
    19
    Cheers guys - I just need to satisfy myself as I'm sure the engine is not the original and has been changed previously but the original engine cam belt cover swapped over.
  1. actual engine number location (1.8T)
    By teo420 in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th July 2011, 18:06
  2. Location of Engine number on 2.0TDI
    By glasgowal in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th November 2010, 13:40
  3. Location of Engine Number on AEB?
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st February 2010, 12:55
  4. Engine number location
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th October 2007, 22:34
  5. location of engine number...?
    By Pete69zx in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2006, 21:22
