Badger5JMB Retrofits
Results 1 to 10 of 10
    Jul 2011
    Teesside
    327
    Wheels painted or powder coated?
    Was thinking of getting my alloys done in some sort of grey. Was going to get them powder coated but my friend has told me his business now does wheels but they are painted. I've seen some wheels he has done and they look great but I think powder coating is better isn't it?
    Or are painted wheels ok?
    Any advice or comments would be great, thanks in advance
    Mar 2009
    589
    Painted is fine but powder coated is better its a harder finish i think !
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,491
    i always go PC
    paint is fine if the painter knows what hes doing
    Feb 2011
    North Wales
    71
    Powder coat
    Dec 2011
    Hockley Essex
    309
    Paint is fine but make sure you use a two pack lacquer to finish them off to protect them .
    Sep 2010
    Whitehaven, Cumbria
    59
    I had my wheels painted. The paint just peeled off so sent them back and they done them again, and now the paint has started to come off again.
    I would say it would be okay if the guy knows what hes doing like bez says but id be safe and go with powder coat
    solaris's Avatar
    Slough, Berkshire
    404
    My wheels were chemically stripped, filled, prepped, powder coated, painted then laquered. As you can imagine its better than a factory finnish.
    Answer to your question:- Do it correct the first time or you will have to do it again.
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    bigmoylan's Avatar
    Feb 2012
    Walsall
    38
    If you're going for one solid colour and you're looking at paying for both, personally i would go powder coated.
    the only advantage of paint is you can have more than one colour. Powder coating is a much stronger finish and takes some chipping.
    a slight kerb on painted wheels will cause the surrounding are to flake.
    Jul 2011
    Teesside
    327
    I think its powder coating for me then, thanks for the replies guys
    Apr 2012
    59
    powder coating is a stronger finish but if you kerb you wheels whether their painted or powder coated they will chip regardless.
    i always paint my wheels and have never had a problem with any flaking even when i have caught a kerb :-( if the wheels are prepped properly so the paint that you are applying can key properly then they will not flake,
    as mentioned above always use 2k products never use 1k or airdry paint/laquer as that does tend to crack up and flake.
    In short if the painter knows what he is doing and uses the right paint you will be fine .
  1. 8P3 S3 Standard Wheels - Powder coated Black?
    By taylorc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th February 2011, 22:52
  2. to get my Avus wheels refirbed or powder coated???
    By danger S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th January 2011, 02:48
  3. Is it best to have wheels powder coated or sand blasted and sprayed?
    By jack.s in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th January 2011, 14:49
  4. Powder Coated Wheels
    By Nilz in forum Detailing
    Last Post: 25th May 2010, 12:24
  5. wheels Powder Coated, milltech cat back exhaust, forge dv and tints
    By ALP A3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 17:56
