AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    Feb 2012
    West Wales
    161
    A few wrapping questions before I get started
    I want to wrap the interior shiny bits in carbon. Mine are looking a bit shabby and I like the carbon look.
    I'm going to do with interior bits, the front grille and the exhaust cover thingy on the rear bumper.
    Now for the interior a bits I'm assuming 10X120mm sheets will do the trick around the dash bits and probably 20x120mm for the ashtray and the bit around the stick.
    The grille I'm not so sure about - do you run the wrapping around the outside or cover the whole grille in say 120x120mm and cut out the middle and trim round till its tidy?
    The rear bumper bit is probably similar to the interior bits.
    When heating it can you use a hair dryer or does it have to be a heat gun? Why do you heat it up before applying it?
    Any help or tips would be really appreciated.
    wallace78's Avatar
    Mar 2012
    belfast
    146
    heating it up makes it more applyable yeah a hair dryer is fine thats what i used 2 do mine the other day!
    Jan 2011
    Surrey
    56
    Me and a friend are starting a business doing vehicle wrapping and we first started off using hair dryers which took a while but can be done. The wrap is like a glue, when its cold it won't really work but when it's warm its sticky as f*ck. Just take your time as it can get very annoying at time and good luck
    Audi A3 2.0T Quattro Sport
    Power Vinyls Stage 1 Remap 255bhp - 276ft/lb, Rev D DV.
    http://powervinyls.co.uk Coming soon....
    Feb 2012
    West Wales
    161
    Cheers guys, will start with the dryer first and see how it goes.
    Another thing - removing the exhaust trim bit - I've read it just pulls off - is that right?
    Alex C's Avatar
    Lizard, Cornwall
    2,595
    Alex S3 AMK
    Bilstein B8s, H&R Springs, Neuspeed ARBs, Genuine 18" BBS LMs & LCR Brembos
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    537
    Quote Originally Posted by eddscott View Post
    yep, check under the car first and make sure there aint any screws holding it on like mine had, then crouch down and start at one side, pull it towards yourself, you think it will snap it but it is quite flexable and should come out, then do the other side same, then pull the rest and it should pop out.
    I must tell you though, start wrapping on small stuff first to get a feel for it, and try and get the carbon to go the same way if you know what i mean, i stuck mine on then used the heat gun to pull the access wrap round to tuck it around the back of the object your wrapping, and it sticks like sssshiiiit to a blanket.
    Anything with curves will set you back a bit but like i say, the more you do it, the better you'll get
    Jan 2011
    82
    what about the bit of chrome/alu on the bumper where the boot shuts does that come off?
    Cribbon's Avatar
    Jun 2011
    Hainault Essex
    154
    get a screw driver covered in a cloth and gentle prise it off starting at one side!
    bigrich690's Avatar
    Dec 2011
    537
    Quote Originally Posted by Cribbon View Post
    +1 i tried it and it does come off same way
    Feb 2012
    West Wales
    161
    How do you do the grill?
    Do you have one long thin sheet and run it round the chrome or do you have a big square and cut the middle out?
    Have a friend who is going to wrap the chrome window edging in Matt black in May.
    Macdoon's Avatar
    Essex
    1,564
    Wrapped my interior, old grille & rear chrome strip.... I got myself a role of carbon 1m x 1.5m, cut out a piece large enough to lay over the grille surround and cut out the middle then used the wifey's hairdryer to warm and mould.
    there was plenty left to wrap the rest.
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Macdoon's Avatar
    Essex
    1,564
    Here's an old thread
    Carbon wrapped pics
    Mac
  1. Car Wrapping?
    By A3 Sport in forum Insurance - Sponsored by Sky Insurance
    Last Post: 20th July 2011, 19:25
  2. Have done some carbon wrapping :)
    By paulsaudi in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th July 2011, 21:01
  3. done a bit of wrapping
    By davsa4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th July 2011, 08:55
  4. vehicle wrapping
    By iain audi a3 1.8T in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 22:35
  5. Car Wrapping
    By Ibiswhite10 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th October 2010, 20:04
