Can any one help me solve my ongoing issue with my hvac flap
Basicly I've come to service the car all fine and then running the diagnostics the hvac flap was showing errors, fixed this before pain, anyway that is now fixed but I'm not convinced that the flap is in the correct passitions. When I set the air con to recirculate the flap opens half way is this correct? Normal flow the flap is closed
I had to remove the motor remove casing and the cogs had all seized some genre purswation and some grease it's now operating correctly, vagcom connected shows value 1 on basic measurements in the hvac all 1-5 go up ascending however value 6 (fan /recirtulation flat) goes the other way
Is this normal
Is this normal
