Thread: URGENT HELP!
    Sep 2011
    south yorkshire
    30
    URGENT HELP!
    this is driving me insane now. the cars a 2.0 tdi the battery light flickers when driving hard are round corners,and sometimes even cuts out! then turns back on has though the battery has been disconnected then back on.... but even more wierdly the DPF warning light comes on the CAN display when the car turns back on after its cut off.... but i dont have a DPF because mine is the 140 BPW engine, battery is fine and alternator has been tested. ive had it plugged into VCDS and the over boost code came up ive had the VNT's cleaned and now its going to the garage for a new turbo does anyone know if all these faults are linked? sorry for the speel but am at wits end with it now and am just goner sell it if it carrys on.
    Sep 2011
    south yorkshire
    30
    aww come on guys id be happy to help anyone on this site, surely my car is not the only one on here what does it?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Check the earth straps on the engine.
    arnoldlog's Avatar
    59
    I take you have checked the earth is ok, it could be a damaged loom. and for your ref BPW can have DPF's
    27,075
    Yeah I'd go with that, the grounding point sometimes corrodes, so could be shorting when turning.
    Sep 2011
    south yorkshire
    30
    ok cheers guys, the good news is that it was the alternator. ive learnt quite abit about the car this weekend which i didnt know... it does have a DPF! i just thought it was the newer 170 models... guess not the turbo and DPF are fine, but il defo be getting the DPF removed for more MPG!! anyway cheers for your input much appericated
  1. Urgent help please!
    By gkf9 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st November 2011, 19:10
  2. URGENT HELP
    By zaeem in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2010, 11:33
  3. urgent help
    By karlharcourt in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th February 2010, 18:32
  4. URGENT HELP PLEASE!
    By david_phillips95 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 26th January 2010, 23:45
  5. URGENT HELP please
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 22:42
