JMB RetrofitsChris Nott
Results 1 to 17 of 17
    Sep 2008
    Chepstow, South Wales
    Indecisive auto wipers
    Driving along in the rain yesterday, the wipers were wiping intermittently and then onto slow speed as the rain got heavier, but every now and again it was doing a high-speed wipe - felt like the auto wipers were being slightly indecisive.
    I've had auto wipers in a BMW and a Golf mk4 before and neither of them did this, so I'm wondering if it's a fault. Does anybody else have experience of this? Is there a sensitivity that can be turned down in VCDS?
    Thanks.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    There's a sensitivity control on the wiper stalk. Up = maximum sensitivity, down = minimum sensitivity with a few steps in-between.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Sep 2008
    I should have said - it's already set to minimum sensitivity on the wiper stalk
    27,114
    Quote Originally Posted by PetrolDave View Post
    Really, I thought that speed position was only when it was up 2 notches, as 1st notch is auto & the speed setting wasnt active in auto mode.
    Sep 2009
    worcester
    1,097
    im with petroldave, was messing with mine yesterday in the rain and that little thumb wheel thing deffo changes sensitivity even when on auto
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    You're mixing up speed and sensitivity.
    First position = auto, with sensitivity controlled by the thumb wheel and can wipe intermittent, slow or fast speeed.
    Second position = slow speed continuous
    Third position = fast speed continuous
    Sep 2008
    Yeah, so anyway... ( )
    Has anybody else experienced anything similar, or should I be booking it in at a dealer for them to diagnose?
    fooby's Avatar
    Apr 2010
    40
    my auto wipers are a little inconsistant, not sure ive noticed the same as you, but do notice for example stopping completely, when actually its raining quite a bit....that kind of thing.
    pita imo. might turn them off!
    out of interest, how olds your windscreen? mine is original really stone chipped, so have always wondered if a new windscreen might make a difference?
    27,114
    I'll have a play as swear mine dont do this on the 8P & my B6 didnt react that way, I know the 8P can be coded with a chassis specific sensitivity, but who knows on the B6/7.
    I cant understand the logic in that either, thats not to say you're wrong Dave, but audi's thought process, as you'd have to constantly move the thumb wheel back if used on non auto mode.
    Sep 2009
    worcester
    1,097
    Quote Originally Posted by alex.stanley View Post
    wait untill it rains again n see what happens, noticed mine are sometimes slow to clear rain than other times, possibly relevant to road speed or could be that simply the required amount of rain drops did not fall on the sensor, afterall rain fall is random
    Jan 2012
    14
    Im not trying to throw another teory into the mist but this is how i got tought they work.
    First notch up:
    To start with they willbe on Normal Auto which means that they willl look at the time it takes for the eye to have droplets on the window/ get submerged in water, if it gets submerged in X msecs it will go to high speed etc.
    When you move the thumb wheel at all you move out of auto wipers and it is controlled on timming between strokes only! you adjust the timing, this is why you will never get the high speed once you have moved the tumb wheel.
    If you want to be back in auto you turn them off and back on, but then the thumb position means nothing once again.
    Everyone knows the next notches up so i will not bother.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    Add A4_MaJiK on Facebook Visit A4_MaJiK's Instagram Channel
    I'm pretty sure ALL the notches just adjust sensitivity and not speed. If you're having intermittent problems, try cleaning or wiping the area of the windscreen where the sensor is located (behind rear view mirror) and see if that helps it at all.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    Quote Originally Posted by AEM_Bulldog View Post
    +1
    If you have auto wipers there are no timed intermittent settings, all the switch positions are just variations on the sensitivity.
    Chugger
    North Devon
    2,716
    Anybody read the manual? Lol... On mine I think the adjustment chances sensitivity, as it goes and all speeds regardless of the position.
    Try rain-x on your windscreen, I found that my auto wipers were loads smoother after using that
    57 A3 2.0 TDI Sportback (140)
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,536
    Quote Originally Posted by sportstractor View Post
    Yes, that's why I know it's a sensitivity adjustment.
    A4_MaJiK's Avatar
    Jul 2012
    Leicester, UK
    822
    I really need to give this a try in that case. My wipers do judder slightly but have reduced after I wiped the blades down.
    Sep 2008
    This has become a major annoyance for me - it's still doing it. I end up driving down the motorway in pouring rain (but not enough to use "speed 1") with the wipers off and the using the flick function to decide myself when they should wipe. Not particularly safe.
  1. How to fit Auto Lights/Wipers & Auto Dim Mirror to 2006 RS4
    By JR Tuning Ltd in forum General Technical / How To
    Last Post: 20th November 2010, 19:02
  2. Auto Lights/Wipers v Manual Lights/Wipers
    By A3_SSS in forum A3/S3/Sportback (8P Chassis)
    Last Post: 11th July 2009, 13:32
  3. Is it possibe to retro fit Auto Wipers and Auto Lights
    By StuOwen86 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2009, 20:44
  4. Auto wipers please help!
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th July 2006, 11:48
