Monster MotorsportChris Nott
    Jan 2012
    9
    B7 cab alarm code
    Hi all my alarm on my 3.0 tdi b7 cab has started to go off repeatedly over the last 4 days. I lock the car and then after about half an hour it goes off. I have a friend who has plugged in and found that its the interior motion with an error code.
    Error code : 01370-035
    And Kwp1281
    can anyone tell me more about what this code means and whats needed to fix it. I have turned of the motion sensor for the moment to see if it stops the alarm going off.
    Regards Liam
    Jan 2012
    9
    Ok after turning the motion sensor off for the night, I have had no alarm triggers. Any ideas of which señor may need replacing.
    Regards Liam
  1. B7 Cab adaption code 62 bits 1 & 2 enabled but not quite functioning correctly
    By o0timbo0o in forum VCDS (formerly VAG-COM) forum
    Last Post: 7th October 2013, 16:26
  2. A4 3.0 Cab alarm siren location, please
    By kressy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 23rd November 2010, 22:51
  3. Alarm arm beep code?
    By griswold in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th July 2010, 23:46
  4. A4 cab 1.8T Alarm Siren
    By Acidic32 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st January 2010, 20:48
  5. A4 1.8T Cab Alarm System
    By imported_stranks in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 27th August 2004, 11:46
