    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    537
    Reverse parking sensor problem
    When I bought my car it had reverse parking sensors on but never worked, I was wondering if there was a common fault with these and if there was an easy fix or at least somewhere to start looking before getting expensive, they make a long beep sound at the moment when you put it into reverse, then doesn't make a noise after that when you put it into reverse, unless you turn off the ignition and then on again.
    In one of my old service bill, Audi quoted £200 to repair the problem but again this was before I owned the car so want to have a go of trying to sort it myself , any help would be much appreciated, thanks.
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Usually its one of the sensors that's had died its a common problem .
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    bigrich690's Avatar
    Dec 2011
    537
    How would I know though, if I unplug one would the rest still work or would that also cause it to stop?
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    Not sure if they will work if you remove, vcds is the best way this will show a sensor fault.
    F
    bigrich690's Avatar
    Dec 2011
    537
    Guess I'll have to spend more money and invest in one
  1. Aftermarket Parking Sensor reverse light feed question
    By Ninja21 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th February 2012, 14:02
  2. Parking Sensor Problem
    By Ian W in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th October 2011, 13:19
  3. Reverse parking sensor switch.
    By benjie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2011, 17:39
  4. Parking Sensor Problem
    By bodders in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th October 2010, 22:39
  5. Retro-FIT for Electro-Magnetic Reverse Parking Sensor (Not Ultra-Sound)
    By fesss_84 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th December 2007, 19:57
