Volks AutosMonster Motorsport
Results 1 to 19 of 19
Thread: parking sensors
    bearder2006's Avatar
    Jun 2009
    205
    parking sensors
    think one of my parking sensor have gone any idea of price or part number 2006 cab
    26,762
    Sensors run at about £70-80 mate, then need painting, assuming oem of course, have you got a long beep at rear when sticking in reverse?
    stocky#1's Avatar
    Sep 2006
    63
    Can you increase the volume of the beeps when you have parking sensors already?
    26,762
    If oem then yes either via vcds or dis.
    stocky#1's Avatar
    Sep 2006
    63
    Yes they should be OEM
    Any chance you could tell me what to change?
    Also don't forget about that AUX in you mentioned before. Cheers
    Jun 2010
    South Wales
    60
    Hello NHN mine beeps sometimes but works fine. What is the long beep. I thought it could be because the car was rolling forward slightly when I engaged reverse.
    26,762
    Its an error on the system which could be a sensor, the buzzer or the module at fault, needs a scan or measuring blocks checked to determine whats causing the beep.
    Jun 2009
    205
    yes it has a long beep
    24
    Had this on mine, long beep is just to let you know they're not working and not to rely on them.
    Unfortunately the guys at my local dealer did not know this and when I put it in for them to be replaced they promptly reversed my car into another one when moving it into the body shop. Even though that's the only thing it was booked in for.
    Jun 2009
    205
    Ive tried put it in reverse with ignition on 3 are load ticking and one is very quiet , does this sound like one has gone ?
    26,762
    Could try swapping them round see if it changes on a different loom connection, but its probably a sensor at ault.
    Jun 2009
    205
    any one know part number please
    26,762
    There are varied ones tbh, whats the diameter of yours ones?
    Jun 2009
    205
    not shore
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    749
    Quote Originally Posted by bearder2006 View Post
    not shore
    If you ring Audi and give them your VIN number they should be able to tell you the part number...
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Jun 2010
    South Wales
    60
    How do they fit into the bumper?
    26,762
    Bumpers come with brackets fitted.
    Aug 2010
    80
    i've got one of a s4 cab 2008 in met blue its got number 1 687 755 A if its any good to you
    26,762
    Thats not it.
  1. 8L S3 Parking Sensors
    By Ian W in forum Parts Requests
    Last Post: 3rd November 2010, 17:43
  2. Parking sensors
    By swarcup in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th October 2010, 22:30
  3. Parking Sensors
    By b00zehound in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th December 2008, 19:27
  4. Parking Sensors
    By djcormie in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 29th May 2008, 09:01
  5. parking sensors
    By Mustafa4hmed in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th April 2005, 14:20
