Badger5Monster Motorsport
Results 1 to 10 of 10
    Sep 2011
    Worcs
    57
    A4 Cab Boot lever adjustment
    My plastic guard device that you lower via a lever when you want the roof down keeps coming off it's rather crappy hinge. I've looked into seeing if there is some sort of adjustment that can be done and everything seems to be fixed which leaves me having to pop this plastic thing back in place each time the boot is opened.
    It is ok when the lever pulls the guard thing up but as soon as the you want the roof down and therefore use the lever to lower the guard it keeps coming off.
    Wonder if anyone has any ideas before i go down the road of some elaborate sleeving system
    A4 B7 3.2 Quattro Cab
    jjmurphy21187's Avatar
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    What part is actually coming off? Is it the black plastic end of the cover which you see when you open the boot or the lever itself? I've never had any prolonged problems with mine apart from the black plastic cover not being attached when I first got it.
    If its the plastic cover then there should be two plastic 'legs' on either side which clip into pegs either side of the boot... have they been snapped off or are they still there?
    Car: 2007 A4 3.0TDI Quattro S-Line Cabriolet
    Mods: Pipercross Panel Filter, Smarttop, LED Plate Bulbs, LED Interior Bulbs, Blue LED Needles, Remap, EGR Delete, Custom Stainless Exhaust (4" Slash Tips), Cupra-R Splitter, Embossed Number Plates, 19" BBS CH Reps & Vredestein Ultra Sessanta's, 12mm TPI Spacers, -30m H&R Springs, MTEC Black Edition Brakes (Dimpled & Grooved), Mintex Pads, RS4 RARB, Vibe Square Subwoofer in Ski-pass & Alpine MRP-350 Amp
    VCDS - PM for details (East Midlands)
    Sep 2011
    Worcs
    57
    Quote Originally Posted by jjmurphy21187 View Post
    Yeh , its the plastic pins , they are still there but for some reason the guard/flap keeps falling out,but it does not seem possible to adjust the position of the pins to secure the flap/guard
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,424
    tiger seal them on
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Agreed, they appear to be fixed...
    Just looked at mine and they only appear to be fixed using a single bolt into the top of the boot. Without taking the trim off I can't see if there are any other holes you could move them to (doesn't seem like it should be necessary though).
    I assume you've checked the plastic legs/feet which clip/slot into the movable boot 'roof' and they're all intact etc?
    As a last resort you could remove the pins from either side, drill out the plastic pins and replace them with longer bolts or similar to get a more secure fit...
    Sep 2011
    Worcs
    57
    The plastic clip that has tiny wheel like things on them allowing it to move I have discovered is missing a tiny wheel on one of the sides .. replacing that i would imagine will be £££ so If there was no other obvious way to adjust, I was going to sleeve over the pin and into the receptacle by as both are plastic there is quite a loose fit.
    Sep 2011
    Worcs
    57
    Found the wheel thing ! ha
    Removed the guard from the car and it seems like the plastic has worn away .. so simple fix from here is a metal washer and some araldite !
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Nice work! Congrats on getting the better of it!
    Aug 2011
    London
    23
    I took mine off and have left it like that. I don't see the need of having it there. everything still works fine.
    Tiptronic
    Jun 2010
    Nottingham, UK
    820
    Quote Originally Posted by A4 3.2 cab View Post
    Without the end cover I don't think you can use the level to adjust the height of the boot? Which is fine if you never need to I guess...
  1. Help please! A4 Cab boot won't open :(
    By wywywywy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th March 2013, 12:28
  2. help needed with boot on b6 cab
    By cabgordy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th June 2010, 22:30
  3. Running power to the boot? (B6 cab)
    By wywywywy in forum In-Car Entertainment
    Last Post: 31st May 2010, 20:17
  4. A4 Cab Boot - Whats This?
    By old-man in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 11th May 2010, 21:22
  5. HELP with audi a4 cab roof and boot
    By little ted in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 31st May 2009, 11:14
