Volks AutosEM Tuning
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    Air bag warning light
    My airbag warning light came on a few weeks ago, so I had it reset but a couple of weeks later it's come on again.
    The fault code was apparently to do with one of the seat belt pretensioners. Searching some old threads I see that this can be caused by a loose connection in the cable that runs under the front seat, from each seat belt buckle.
    Assuming I can find where the problem is and sort it out, can I clear the airbag light without getting it reset again? In one thread it said to disconnect the battery for a bit, but in another thread it said that won't work and must be cleared through VCDS?
    thanks
    Audi A4 (B7) 2.0T FSI SE Quattro
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    It can be done easily by VCDS, I did it when I forgot to reconnect my driver airbag after retrofitting cruise. I haven't tried disconnecting the batter, its worth a go if you don't have access to VCDS.
    2008 A5 3.0TDI
    dannyboy75's Avatar
    Oct 2011
    Dorset, UK
    91
    cheers Ben
  1. Air Bag Warning Light
    By Mike071288 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2011, 22:58
  2. Air bag warning light
    By dribz-s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd May 2009, 21:44
  3. Air Bag Warning Light
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd October 2007, 09:37
  4. Air Bag Warning Light
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2007, 17:26
  5. Air Bag warning light?
    By c11rgd in forum Diesel forum
    Last Post: 6th September 2005, 01:37
