Volks AutosChris Nott
Results 1 to 21 of 21
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    537
    Audi phone question
    When I bought my Audi it had these wires and brackets fitted to it, are they the originals for a phone bracket and if so what phone is it comparable with?
    Cheers, rich
    27,096
    It would be compatible with the audi cradle, that can have many different adapters fitted, you need to check audi uk site for which phones the bracket will support.
    bigrich690's Avatar
    Dec 2011
    537
    Thanks bud will have a look
    bigrich690's Avatar
    Dec 2011
    537
    sorry to bring this back up but i dont know what im looking for, i need to perchase one of these.....
    ............can someone point me in the right direction on how to get one and what the part number is, secondly i need the other part that would fit my iphone 4, how do i get one and where or what is the part number for that please, much appreciated
    27,096
    Are you saying you dont have any form of phone connection currently or you want to upgrade your BT to have cradle?
    If you dont have any phone system including BT then send me a PM, as can supply/fit all of this including cradle for you
    bigrich690's Avatar
    Dec 2011
    537
    I discovered I have the Bluetooth earlier but who ever owned the car before removed the cradle and tucked the wires away so just need the device (s) so I can hook my phone up every time I get in the car
    27,096
    Sorry but I cant see the point if you have BT already, what is it you want to achieve that BT doesnt?
    bigrich690's Avatar
    Dec 2011
    537
    good point, i just hate those holes that are in the dash so would have liked to have the cradle so i can connect my phone by plug in if that is possible? i could really do with seeing someone who has one fitted and see for myself what it really does etc etc clearly im missing something here and what ever anyone says i dont seem to grasp, so i'll leave it for now and when i get to audi in the park of somewhere where someone has one i'll take alook then and get my head round it
    27,096
    I still cant understand what you need to work out mate, its just a cradle which would give you pretty much all the BT would, except it would of course charge the handset, but you need to check with audi if they have the adapter for the cradle to use with your handset, if the hole bothers you, then either get someone to plastic weld & then dash repair guy paint it for you or get a new console piece to cover up the whole.
    bigrich690's Avatar
    Dec 2011
    537
    ok thanks for replying to my stupid question, you clearly know all about this and i have no idea so i'll leave it, i just cant understand why i have wires for a cradle set but have the BT set up aswell? and when the phone rings i have to dig it outta my pocket whilst im driving and answer it whilst if i had the cradle i could just reach over and tap it? and ive also noticed that when i answer it, every time i have to activate audi speaker phone on my handset to hear them or else i cannot hear who rings, anyway of sorting that?
    27,096
    Mate I think you need either some coding done or an mfsw installed so you can answer & make calls without taking out of your pocket, PM me if of use as I can sort out for you
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    My 2005 Cab came from the factory with Bluetooth module and the cradle on the dash - where your holes are..
    The previous owner fitted the iPhone 4 adaptor to the cradle, This charges the handset and *might* use the GSM antenna in the car, but I'm not sure of that.
    You probably want something like this, but best to check it will be compatible with your car..
    NEW GENUINE AUDI A4 B6 GREY MOBILE PHONE MOUNTING HOLDER - 8E2 862 401 F 26Z | eBay
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Mine had bluetooth and the cradle when i went to view it at the garage. I hated the cradle and managed to get the garage to agree to remove it and change the console.
    A4 3.0TDi SE Quattro Auto. Factory-fit: RNS-E/bluetooth; F/R parking sensors; full leather/heated front seats; cruise. Retrofit: Remap; Eibach 30mm lowering springs, RS4 RARB; MTEC drilled/grooved discs; 18" RS4 alloys; VW fan washers; Kinetic Digitizor DAB; Blackvue DR380 camera; front armrest; ambient lighting; white LED lights; autodim mirror; Cupra splitter; S-Line door blades; tints; UK pressed plates; MFSW; SDS; TPMS; LED Taillights and DRLs. RS aluminium pedals
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,676
    Quote Originally Posted by bigrich690 View Post
    How hard have you tried? I keyed "Audi Phone Bracket" into Ebay's search function, and look what it came up with!
    Click on link
    May 2011
    wales
    74
    bigrich690,
    There are a few benifits going down the route you first mentioned.
    Bluetooth is not all its cracked up to be, it can drop calls, bad reception at times, can be troublesome, anyway using a cradle and dedicated iphone adaptor.... you can charge the phone, use the cars inbuilt ariel, works perfectly.
    I still use bluetooth with my nexus phone, but if i go away for holidays... i take my trusted nokia and use it via my adaptor/cradle fitted to the armrest.
    john
    27,096
    BT isnt the issue & it doesnt drop calls unless your bt device is faulty, that would be the handset & network signal, the distance between the BT system & the handset are so minimal, that it would have the best BT connection it could have, its purely the handset/network that causes these issues.
    Obviously when its plugged into the base unit then it would utilise an external antenna which is of course best for using whilst driving about, but mine has worked flawlessly & I've had a fair few versions now, so for me, unless your network has very bad patchy signal areas that an external antenna may help with, I'd stick with BT.
    bigrich690's Avatar
    Dec 2011
    537
    wow lots of replys there but all very helpful thank you everyone
    May 2011
    wales
    74
    NHN,
    With due respect, i used my old nokia via BT many months before setting it up via the armrest base unit, now the call quality on BT was without doubt noticably inferior, but changing back to the armrest base unit, it became a different ball game, crystal clear, no interference whatsoever,
    While i agree, your BT quality can only be assured with both handset and network being top notch, it doesn,t take away the fact that BT will always be second best to the base unit connection.
    By the way, i have had in the past 3 phones using BT and base unit, they were not all faulty, but the results are the same.
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,533
    Quote Originally Posted by johnmandy View Post
    i used my old nokia via BT many months before setting it up via the armrest base unit, now the call quality on BT was without doubt noticably inferior, but changing back to the armrest base unit, it became a different ball game, crystal clear, no interference whatsoever.
    Nokia are known in the mobile phone industry to have a "unique" Bluetooth stack implemented by themselves, that doesn't conform to many of the industry standards - since Bluetooth is a self-certified standard they can do this.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    27,096
    I dont disagree in many different industries/uses, that a cable connection is better as its not as susceptible to outside sources as such, but given the distance & usage that doesnt require so much bandwidth, I'm finding it hard to see why you are having issues unless there are other factors involved, like handset age, module age, handset FW version, BT versions in use, there are many contributing factors that can affect the discussion point tbh, even the sound system in use can affect.
    Most modern day handsets have BT V2 anyway which is tbh very good, so should have good quality, but I have issues with the BT on my Samsung Galaxy Ace which is a good handset with new technology fitted & this is down to the handset android versions, not the BT itself, call quality is very good but disconnects sometimes.
    But, maybe you have an issue with your BT module as the cable/cradle isnt using the wireless part of this, who knows without swapping out for newer.
    All I can say is for me, the BT is very good overall & allot more flexible.
    Collecting Rings
    Nov 2010
    Oxfordshire
    104
    I have this phone bracket and the entire center console if someone wants to make me a decent offer and it'll help out a forum member. Hardly any phones work with it and the bluetooth works well on it's own, as NHN has said. But that doesn't change the fact that I have a load of Audi plastic in my loft I want to get rid of.
  1. Replies: 4
    Last Post: 18th February 2011, 18:57
  2. Phone question.
    By Quietlife in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th January 2010, 13:48
  3. Phone Question Please!!
    By A3Tom in forum General Chat
    Last Post: 15th August 2009, 22:38
  4. Phone question
    By jonmusicman in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 16th November 2007, 19:50
  5. Bluetooth phone question
    Last Post: 26th December 2006, 21:10
