Chris NottSky Insurance
Thread: Radio Upgrade
    jimmc's Avatar
    Feb 2012
    Dudley
    9
    Radio Upgrade
    Can anyone tell me if you can remove a symphony11 out of a2006 a4 cab and replace it with a symphony soul out of a 57 plate a4 advant the wiring connectors seem to be different
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,532
    Probably the one out of the 57 plate is a Symphony II+ and not a Symphony II.
    You can get wiring adapters from e.g. Kufatec, but the remaining problem will be the antenna connectors and diversity system. the Symphony II uses frequency diversity but the Symphony II+ uses phase diversity and that means cars with Symphony II+ have a different antenna system.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    jimmc's Avatar
    Feb 2012
    Dudley
    9
    Thanks for your reply dave but the question is dose anybody no were i can get the change over done or would it work out cheaper to fit a sat nav unit which i dont really want also you are right the new unit i have is the one with no tape deck but the screen is abit bigger
    27,089
    You'd be best to install an rns-e mate if you have the older iso connectors, swapping the antenna systems over without much more gain would be expensive, when installing an rns-e would give you so much more for probably near the same price, which means your antenna system would be compatible, give me a shout if of use, as I supply/fit these systems.
    jimmc's Avatar
    Feb 2012
    Dudley
    9
    Thanks NHN i was thinking it might be a big job so i might need to go for the RSN E option were are u based and whats the cost for the change over
    Cheers jim
  1. Replies: 4
    Last Post: 16th June 2010, 12:30
  2. Std MY2000 A3 Audi Concert Radio Upgrade
    By Audilee in forum In-Car Entertainment
    Last Post: 29th September 2009, 23:27
  3. Woo! New Car and Radio Upgrade Advice!
    By Silky-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th February 2009, 09:48
  4. A3 radio upgrade to sat nav
    By maars in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th June 2007, 00:20
  5. Delta radio - Upgrade to DVD MP3 or Hard Drive or Ipod?
    By simong in forum In-Car Entertainment
    Last Post: 30th May 2005, 22:56
