JMB RetrofitsBadger5
Results 1 to 12 of 12
    Macdoon's Avatar
    Essex
    1,569
    Crossed/drilled discs on a 170 anyone
    Hi Gang
    Is anyone running crossed & drilled brakes discs on their 170, if so where from, recommendations.
    Mac
    A4 B8 (09) 2.0 TFSI (211)
    Black Gloss RS4 style mesh grille, Black Gloss fog grilles, Black Gloss splitter trim, Ice White fogs, Tints, Black A8 boot rings, Black Badges, Dynamik boot spoiler, LED interior, LED number plate lights, Brushed steel vinyl wrapped interior.
    Feb 2012
    West Wales
    161
    I always thought aftermarket drilled were best avoided because they were prone to cracking around the holes?
    Are S4 brakes beefier? Maybe source them from feebay or a breakers?
    quattronly
    Jun 2011
    SW Scotland
    105
    Quote Originally Posted by eddscott View Post
    I think he means the cross-drilled ones from the 2.0T Special Edition. I asked about fitting these, but its not a straight swap as the discs are larger so need different calipers too.
    Macdoon's Avatar
    Essex
    1,569
    Not necessarily from the 2.0T, but i have seen some running cross drilled discs on 170's, just wondered if anyone on here had any knowledge of them.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,510
    M-tech when i got my 140 vant they had just been fitted all round
    Macdoon's Avatar
    Essex
    1,569
    Cheers Lee, just googled M-tech, they look great, and a good price.
    Any recommendation on pads or would you use MTEC's
    Mac
    bez101's Avatar
    Jul 2008
    8,510
    they got red stuff in them
    Macdoon's Avatar
    Essex
    1,569
    Sold lol, don't suppose you would know the exact dimensions of the 170 discs, Audi said 288mm x 25mm, but i've measured and am sure they are 312 x 25
    bez101's Avatar
    Jul 2008
    8,510
    the ones on this 06 140 are 312
    Macdoon's Avatar
    Essex
    1,569
    I'll be popping the wheels off the morra to measure again to make sure, thanks for the info fella, appreciated.
    quattronly
    Jun 2011
    SW Scotland
    105
    Post up your dimensions please as I will probably be going down the same route when replacements are due.
    Thanks.
    Macdoon's Avatar
    Essex
    1,569
    Will do, soon as i get them measured fella
  1. Best drilled discs for 3.2 A3
    By TAC in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th August 2011, 18:16
  2. New pads and Drilled discs fitted!!
    By Dazmo in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 25th June 2010, 21:58
  3. Ebay Cross drilled discs
    By griswold in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th March 2010, 10:51
  4. 320mm drilled discs
    By dan_the_v8man in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd February 2010, 19:53
  5. Drilled Discs for 08 S3
    By d8vil in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th January 2009, 19:16
