EM TuningAH Fabrications
Results 1 to 13 of 13
    May 2011
    Glasgow Area-ish
    62
    Single press unlock?
    Is it possible to reprogram the locking to unlock all on the first press?
    Rastamouse's Avatar
    Welsh Audi Nut
    Aug 2011
    333
    Im sure this is possible i think i had it done on my old mk4 golf, but cant for the life of me remember how it was done! Doh!
    rs4 grill with black wrapped surround,lowered 50/40 on weitec springs,rs4 fog grills,DRL headlights,18" rs4 alloys,Remapped to 175bhp, double din conversion with kenwood dnx7220 headunit,tinted windows,carbon wrapped interior,arm rest retrofit,Led interior lights,ambient light retrofit.Rs4 Pedals,Chrome wing mirrors.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Yea it's done in vag
    May 2011
    Glasgow Area-ish
    62
    My local dealer said it couldn't be done but it seems I was right to doubt them. So can independent specialists do it or can I pick up the kit to do it for sensible money?
    VCDS & TPS Account holder.
    Blackie's Avatar
    Feb 2004
    In a house
    634
    Depends what you want to spend. Always good to have the lead and software.
    Program the doors, make the alarm beep etc etc
    RMH1A4cab's Avatar
    I'm in Cruise control
    Jul 2010
    staffordshire
    524
    Vcds I have done it, can't remember the code and I'm not home to look I'm sure someone will have it to hand.
    F
    ULL VCDS HEX-USB-CAN Interface available in the staffordshire area pm me.
    Aug 2011
    43
    I did this on my S3, dead easy.
    Info from ross-tech site..
    Central Convenience Controller Coding:
    State Bit Dec. Function
    OFF 0 1 Great Britain- alarm system (only with bit 4)
    OFF 1 2 flash on when arming/unarming alarm system
    ON 2 4 selective locking 1 door/all doors
    ON 3 8 activate alarm system
    OFF 4 16 rear unlocking block via speed
    OFF 5 32 locking via speed
    OFF 6 64 comfort functions with remote (adapt in ch 62!!)
    OFF 7 128 right side steering
    OFF 8 256 avant (glass break sensors in rear side-and rear
    windows (if error: safe-LED constantly lit ))
    ON 9 512 1x flash when lock with remote
    ON 10 1024 horn sounds when lock with remote
    ON 11 2048 door/window-logic ( ignition off: No open door
    el. windows works 10 min )
    OFF 12 4096 normal/????-alarm system
    ON 13 8192 No SAFE-function USA only
    OFF 14 16384 insulate-glass PR-nr 4KR/4KV
    Again, we can verify that we did this correctly by adding up all the decimal values for the bits that are ON:
    4 + 8 + 512 + 1024 + 2048 + 8192 = 11788.
    Now notice that bit 6 with a value of 64 and function "comfort functions with remote (adapt in ch 62!!)" is OFF !!! So in order to turn this ON, we need to add 64 to the original coding. 11788 + 64 = 11852. Recode the module with that number. Once you do that, the options in Adaptation Channel 62 should take effect, and you can change the value there to "fine tune" the features..
    If you wanted to add "locking via speed" (where the car locks itself as soon as you reach some low speed), you would add 32.
    If you wanted to turn Selective Locking OFF, (so the entire car unlocks with one press of the unlock button on the remote) you would subtract 4.
    May 2011
    Glasgow Area-ish
    62
    Thanks a lot guys. How much are we talking for the cable and software?
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    VCDS is what I used to do this (the opposite, actually): Ross-Tech Store: VCDS License with HEX-USB+CAN Interface ($US 349)
    or you can get it from one of their UK distributors, e.g. VCDS (VAG-COM) USB PC diagnostics package for VW, Audi, Seat, Skoda cars (1996 on) (£265)
    RMH1A4cab's Avatar
    Jul 2010
    staffordshire
    524
    NHN, (nigel) is an official UK distributer on here that is where most people on here get them from.
    VCDS Supplier
    F
    A4Ade's Avatar
    Back from the dead
    Jul 2008
    Lancaster
    80
    Apologies to Nigel - my suggestion was just the result of a quick google - no personal interest!
    (and he's cheaper, I notice!)
    Quote Originally Posted by RMH1A4cab View Post
    VCDS Supplier
    Aug 2011
    43
    I got mine from NHN, proper gent!
    May 2011
    Glasgow Area-ish
    62
    Thanks guys
  1. To press or not to press
    By audiv6quattro in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th January 2012, 22:21
  2. What happens when you press AUTO?
    By benjie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 14th November 2011, 22:24
  3. Car won't unlock using unlock button on key / key won't start car!!
    By evapor8 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 7th November 2010, 09:42
  4. STOP THE PRESS......
    By hop2407 in forum A8/S8 forum
    Last Post: 14th September 2005, 07:02
  5. Hot Off The Press...A3 1.8T / S3
    By DaveS3Turbo in forum A3/S3/Sportback (8P Chassis)
    Last Post: 6th July 2005, 17:53
