Monster MotorsportChris Nott
Results 1 to 10 of 10
    Nov 2010
    114
    Audi A4 B7 Front Axle Load
    basically the website that i'm trying to order some coilovers off only gives 2 options :
    max front axle load 1080kg or Front axle load 1080 to 1220
    I am unsure of which my car is, its a 2006 A4 S-Line Special Edition 2.0Turbo FWD
    Any help appreciated, thanks
    Nov 2010
    114
    viceroy's Avatar
    Aug 2011
    Johannesburg
    198
    the usual choices are between FWD or quattro. Seeing as though you have FWD, I would guess the choice for you would be max 1080kg
    | 2009 A4 3.0TDI quattro tip | Ice Silver | 19" OEM RS4 style wheels | PDC | Sunroof | Black Leather | Symphony Radio | Aftermarket Navigation & DVD | RS4 mesh grille | Custom mesh fog grilles |
    Dazmo's Avatar
    May 2009
    Leicestershire
    1,775
    Best thing is to ask them before ordering then at least you should get the correct ones.
    However viceroys theory is sound, usually quattro is the heavier load!
    Maritus Blue Audi A4 3.0 V6 S-Line TDi 275bhp, 585nm Torque
    Nov 2010
    114
    No problem thanks
    quattronly
    Jun 2011
    SW Scotland
    95
    There's a plate either on the engine bulkhead or B pillar or boot which shows weight of each axle. Its also handy for knowing the minimum Load Index you need for your tyres. Was a while ago when i looked for mine so can't remember which location i found mine in, but can remember I needed at least a 91 load index tyre on my diesel quattro avant. A lookup on that points to 1230kg, but that's for a diesel.
    Nov 2010
    114
    Right basically there's the VIN number then underneath:
    2005kg
    3450kg
    1 - 1090kg
    2 - 1045kg
    thanks
    Nov 2010
    114
    does this mean number 1 is front axle load?
    bigrich690's Avatar
    Dec 2011
    West Yorkshire.............LEEDS
    461
    the front will be heavier without a doubt, the engine is there...........unless you have put the engine in the boot lol
    Nov 2010
    114
    what i was asking is the 1 and 2 your axle loads or something else
  1. REAR AXLE FRONT BUSHES
    By tonya4 in forum A4/S4 forum(B5 Chassis)
    Last Post: 20th June 2011, 21:36
  2. Need help finding front axle weight..is it on this?
    By kreativeJ in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th July 2010, 22:30
  3. Front axle weight...?
    By will-i-am in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th November 2008, 08:35
  4. FRONT AXLE WEIGHT?
    By vw754 in forum Handling
    Last Post: 12th December 2007, 11:14
  5. Front axle weight?
    By mr.brown in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th October 2007, 19:56
