Volks AutosJMB Retrofits
Results 1 to 14 of 14
    Aug 2006
    44
    A4 TFSI slight hesitation as revs normalise to idle
    My 2.0TFSI Avant Quattro (manual) is experiencing slight issue as the revs normalise back to idle.
    I experience this whilst in traffic (on and off the acceleration) or as I approach lights to come to a stand still. The engine seems to fluctuate in revs for about a second before normalising to 800rpm. Its fine once it gets moving - theres no loss in power or hesitation and the car has never cut out. I have only been experiencing this in the last 2 months or so.
    The car has done 81,000 miles and has a full history. Remapped by AMD and has the revised diverter valve.
    Ive not had it in to get it checked over, just yet. However, I have a OBD reader and there are no faults logged.
    Has anybody experienced this or have an idea where the problem lies?
    Thanks in advance.
    A4 2.0T FSI Avant S Line Quattro - Phantom Black
    solaris's Avatar
    Slough, Berkshire
    404
    Its tough to say without fault codes however the pcv may be on the way out, the stock one is poor anyway so may be worth changing this and/or inspecting the pipes to eliminate it. Basic sysmptoms are eratic idle, boost loss, oil leak so it would be a good starting point.
    Get well soon
    If it's not longitudinal and it's not Quattro..it's not an Audi
    VCDS (VAG-COM) HEX-CAN USB cable carrying member
    2005 A4 DTM 2.0 TFSi Quattro :364Bhp/477NM - Mapped by MRC Tuning
    Hybrid K04 Project ongoing (link to Build thread)
    DMFW + Clutch For Sale
    25
    Hi,
    Does it seem to 'hold on to the revs a bit' also when you press the clutch down between gear change? Mine does both of these and I've been to told it's the clutch switch. I've just not got round to changing it yet.
    2006 B7 A4 Avant S-Line Special Edition 2.0T Moro Blue
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,465
    i had this
    clutch switch was at fault
    solaris's Avatar
    Slough, Berkshire
    404
    This may be the part number for the clutch switch 7H0927189
    Also a picky of where it goes (Number 2)...seems to be a simple enough swap
    razza1's Avatar
    Dec 2008
    Reading - Berkshire
    1,243
    Might be carbon build up on the throttle body (think it was there....), had this on my old one and caused it to hold revs a bit longer.
    07 2.0T SLine SE V2 Quattro, Full Milltek with hi-flow sports cat, APR Stage 2+ 280BHP/325lb/ft, APR HPFP, K&N panel, S4 alloys, Spacers, Black Optics, Eibachs, RS4 grill and fogs, Fog tints, RS4 ARB, RS4 Gearstick, LCR splitter, Black Calipers, Drilled discs, Debadged, Colour DIS, Bose, Adaptive Xenons/DRL, Black/Silver Audi Exclusive leather, Audi Carbon inlays, carbon difuser/B pillars, RNS-E+/Bluetooth, Cruise, Int/ext light packs, Rain/light sensors, mudflaps, LED plate/side/boot/interior
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    Visit Craig Cull's Youtube Channel
    I have exactly the same problem with mine at the same mileage. Is the clutch switch always the case? Or could it also be other problems? Hope you manage to get it sorted mate
    Jun 2011
    Manchester
    248
    Quote Originally Posted by suckedin View Post
    Hi,
    I also get this issue from time to time, usually only when changing from first to second.
    2005 B7 A4 2.0T in Moro Blue
    Interior, Number Plate & Sidelight LED's from T8ups, 18" 9 Spoke TT Wheels.
    BGB Engine Code.
    Aug 2006
    44
    Hi All, just to give you an update on this.
    It was the indeed the clutch switch at fault. Did attempt a clean of the throttle body at first but didn't fix and then swapped out the clutch switch and problem sorted.
    Thanks to all that suggested this as the mechanic wouldn't never had thought of that and no fault codes logged to point in that direction.
    Car does appear to be running smoother due to the throttle body clean, so maybe worth doing both if you are experiencing a similar issue. Bare in mind that throttle body may need adaptation after clean.
    Jun 2011
    Manchester
    248
    Was the clutch switch easy to replace and what was the cost of the new part?
    BGB Engine Code.
    Aug 2006
    44
    About 15 mins to replace.
    Part was 13 + VAT.
    Jun 2011
    Manchester
    248
    Did you get part from ebay or Audi garage?
    BGB Engine Code.
    Craig Cull's Avatar
    Oct 2011
    Leeds uk
    1,135
    just done mine as a result of this post and its sorted the problem. cost me £16 from audi took me 5 mins to change. cheers
    Aug 2006
    44
    Still experiencing similar issues although not as bad.
    The symptoms are of a slight miss at idle when depressing clutch, turning the steering wheel when stationary, using the electrics inc central locking. Its almost like there isnt enough power in the battery or alternator isnt doing its job. Did a battery check and it came up as 13.8 which is normal, no?
    Any help would be appreciated...
  1. 2.0 TFSI Misfire/slight hesitation advice needed
    By B-J-P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 1st June 2011, 21:06
  2. HELP!! Problem with slight hesitation when coming off idle
    By Mattfaced in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th January 2010, 18:32
  3. Slight hesitation on boost
    By blackturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th February 2009, 10:41
  4. Hesitation through revs
    By imported_Robbyc in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2006, 17:16
  5. Slight hesitation
    By niggtv in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st April 2006, 10:18
