ok seeing has no one knows i had a go myself and risked it...
first of for the chrome around the window screen you goner need....
cross screw driver
10mm socket
star drive set
drill
rivets
patience....
ok start off by removing the interior light it just pries off, underneath that there is a 10mm nut remove.
then there is Phillips screws underneath the following
drivers and passengers sun visors the screws are under the swivel point and the clip point of the visors, use a electric screw driver to get the caps off to reveals the screws.
then remove both interior lights underneath the visors. then the visor what comes down over the rear view mirror there is a screw directly under that then once you ve removed all of the above the top part of the interior panel will pries off.
underneath that there is four 10 mm nuts holding the top chrome part to the body.
before you do that un pries the window pillar interior panels (just clips) and pull towards you upwards and it will slide out.
then there is a star bolt which holds on the window seal and the in a recess there is one 10 mm bolt and two rivets down the side just drill them off thats all what holds on the window pillow chrome part this is the same for both sides.all the chrome parts then just gentle pries off without bending. fitting is reverse.
i vinyl wrapped mine in black and looks like a totally different car ive put a few pics on one been the recess of the window pillar bolt,and one of the car before and after. long winded but hope it helps
IMG_0936[1] | Flickr - Photo Sharing!
IMG_0934[1] | Flickr - Photo Sharing!
IMG_0933[1] | Flickr - Photo Sharing!
