EM TuningChris Nott
Thread: airbag light
    61
    airbag light
    Hello my airbag light is on. when put onto the computer it say's it's the plug under the seat. My question is can i change the plug or is there an other way to turn it out and keep it off.. ie, join the wires or put a resistor across the wire's.It's dew mot next month so need to sort it. Many thanks stuart
    61
    can anyone please help
    Jun 2010
    South Wales
    69
    Have you been cleaning the car. I had the airbag light come on after I had moved the seat all the way back to clean the car. Just check the plugs under the car and clear the code. If it comes back then there may be a fault along the line. As far as joining the wires, it would not be solving the problem plus it would be a bugger of a job unless you take the seat out to try to join the cables back up without the connector.
  1. Yellow airbag connector under seat causing airbag light to come on
    By pj123 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th December 2012, 18:46
  2. Removing old seat with detonated airbag. How to? Also Airbag light?
    By Stanley in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2011, 18:30
  3. Airbag Light
    By alex100a in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 24th June 2010, 19:50
  4. Airbag light
    By Eatmydust in forum VCDS (formerly VAG-COM) forum
    Last Post: 23rd August 2009, 19:43
  5. Airbag light help
    By OllyS4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 2nd April 2008, 17:37
