JMB RetrofitsBadger5
Results 1 to 16 of 16
Thread: Xenon fault
    rizzini7's Avatar
    Jun 2011
    Warham, Norfolk, United Kingdom
    728
    Xenon fault
    My drivers head light main beam is playing up. Its fitted with the adaptive ones (move left/right, up/down on corners etc...) The main bean goes out every now and then. But when i flick the steering to the right it comes back on but sometimes goes out again when i straighten the steering. The dip beam works fine and the adaptive works. The car has recently been lowered 30mm and fitted with b5 spring cups. Do i need to adjust or reset anything??? Thanks
    Dolphin Grey 2005 3.2fsi Quattro 6-speed manual A4 Avant S-line, Two tone Leather, Pipercross panel filter, Genuine RS6 style 18" Alloys, Cupra R Lip, Piranha Grooved and dimpled Brakes, Eibach 30mm springs, B5 Front Cups, Rs4 RARB, HEL Braided Brake Hoses, Engine covers, Rs4 Grill, Rs4 style fog grills, Lamin-x'd head, fog and tail lights, Adaptive Xenons, Q5 rear wiper, S4 spring clips, Heated Passat Washer jets, DIS and cruise control
    Now have genuine VCDS in North Norfolk
    Jun 2009
    14
    is it b6 / b7? my b7 s4 used to have flickering issues with the xenon, poteinally the ballast need replaceing.
    rizzini7's Avatar
    Jun 2011
    728
    Appears it comes on when left or right now. Having a front end judder when turning every now and then at the moment. Also got to replace RARB bushes. So will see how it goes when theyre sorted. Hopefully its all linked
    rizzini7's Avatar
    Jun 2011
    728
    Problem still here. Any input before i try new ballast at somepoint
    May 2012
    i would try new bulbs first its the cheaper option. i had both lights that use to go out on my b7 avant, i put some new philips xenon bulbs in and its cured the problem
    Apr 2012
    N. Wales, LL22
    1,224
    i wonder if you have damaged wiring in the headlight that is connecting when the projector moves
    VCDS in North Wales
    2007 A6 3.0TDi S-Line Le Mans Avant , adaptive xenon lights, sunroof, privacy glass, towbar, led rears & randomly rear seat airbags
    1999 Honda S2000 , mcb low milage jap import, fully bushed, mugen exhaust <<< for sale! <<<
    2001 Passat TDi 130 Sport < sold!! http://img.photobucket.com/albums/v343/Ste_Nova/Passat/PB140007s.jpg
    rizzini7's Avatar
    Jun 2011
    728
    Suppose that could be possible last time when fitting the new bulbs in August or lowering in Feb. Where abouts is the sensor for the adaptive for steering???
    ben.w93's Avatar
    Sep 2010
    Devon/Cardiff
    213
    Could be the bulb, my bulbs kept flickering and cutting out. I replaced the bulbs and they work perfectly now. Might be a loose connection on the back of the bulb too as they are fiddly to fit.
    2008 A5 3.0TDI
    rizzini7's Avatar
    Jun 2011
    728
    Its had new OEM bulbs already. So i hope its not them. And when it goes out it only goes onto a dip beam not out all together???? Just after ideas before we take the bumper etc.. off. Ive found someone who will do me a new OEM ballast for £140 so may give that a go. Im just wondering if it could be a fault on the steering end
    Richardesty's Avatar
    loves quattro
    Oct 2008
    Louth
    753
    Quote Originally Posted by rizzini7 View Post
    Well as you'll have seen when you swapped the bulbs, they're just a single bulb - not like the old H4 dim/dip style.
    Listen when you flick your main beam on....
    Your car changes from main beam to dip beam via a flap of metal, the bulb doesn't do a thing...... Sounds like its that mechanism which is failing, and as you'll probably guess links in with the direction control mechanism.
    rizzini7's Avatar
    Jun 2011
    728
    Could be worth me trying to get a look at the mechanism before buying a ballast then. Another bumper off job then . Will try and do it next weekend and swap the ballasts at the same time. Atleast if it changes sides its the ballast. Otherwise the lights seem to work fine
    27,099
    Sounds to me as though the wiring to the bulb could be affected or pulling on the bulb connector when turning, shorting momentarily, I would so s you already planned, remove headlights & check visually, test with bumper of & then refit when happy of course.
    rizzini7's Avatar
    Jun 2011
    728
    Yeah going to give it a go in a couple of weeks when my mate is free. Not sure on removing bumper myself .
    rizzini7's Avatar
    Jun 2011
    728
    Well finally swapped ballasts and drivers side still plays up. So its the headlight and not ballast. Is there anyway to repair or is it a swap job???
    27,099
    Already suggested you need to check visually internals of the headlight, I still think it could be something getting caught internally.
    rizzini7's Avatar
    Jun 2011
    728
    Long update, after still having issues with headlight and ballast (not sure if my mate did swap the ballast or the bulbs in the end ???) got fed up and have now replaced the light and ballast. Also checked and played with all wiring at the same time. And so far so good the issue seems to have gone. Ballast got sold on as repairs a while ago as a dud and last night sold my spare passenger and pos repairs drivers lights and bulbs to new member Sam00Cleveland who is doing a retrofit. Sounds like he knows what he's doing with electrics so hopefully he has more luck with it.
  1. Xenon Fault
    By landopanda in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2012, 21:07
  2. Adaptive bi xenon fault on s3
    By Hanz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th January 2012, 16:35
  3. S3 Xenon bulb fault???
    By chrisp in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th August 2011, 09:45
  4. Bi-Xenon Fault
    By RobinA3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd August 2010, 21:58
  5. Xenon Fault
    By NWMark in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th December 2004, 15:53
